External Wastegate or Actuator
need your help please ,for high boost ( 28 psi - 2.0 bars ) which one is better to use , an External wastegate or actuator ?
If its external which headers do you recommend ?
what are u going to run 2 bars on? I hope not the Porsche.
I have external WGs with a greddy boost controller. U have to get the headers altered and or made...
2001 996TT 3.6L and stock ECU
i have greddy profec s and tial 38 mm external WGs i havent installed them yet r they good ?
UAE996tt where are you going for this kind of work in Dubai, would be interested as i havent found any knowledgeable places here, HOC and Quartermile seem to overcharge and not understand these cars too well
u r right . i might send the motor to U.S but there is a place i might go for it in dubai .the bolt on parts i can order it from U.S which i already have most of them . in dec ill be done . ill let u know if u r intersted .
u r right . i might send the motor to U.S but there is a place i might go for it in dubai .the bolt on parts i can order it from U.S which i already have most of them . in dec ill be done . ill let u know when im done if u r intersted .
no Im runing 22 psI max on C16
sdg1871
10-05-2015 07:05 AM
panas001
09-27-2015 02:51 PM
