dyno day - who will step up?
Old 12-10-2007 | 12:03 PM
drewTT's Avatar
drewTT has a spectacular aura aboutdrewTT has a spectacular aura aboutdrewTT has a spectacular aura about
heres my graph. expected a little more power up top. my torque was wayyy higher, which is a little odd
  #182
Old 12-10-2007 | 01:09 PM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
Those are some smooooooth looking power curves, I'm hoping mine will look as pretty when I get the hybrids with the software.
  #183
Old 12-10-2007 | 01:13 PM
Originally Posted by Harman Motive
I agree that the numbers produced by this dyno are conservative. It is well known through the tuning community that Mustang dynamometers will read on conservative side - I knew this when we purchased the dyno.
My experience with dynos is a little more complete than most. I have now owned two dynos (Dynojet and Mustang), dynoed well over 1,500 cars over the last 4 years, and spent most of those runs performing custom tunes. I have also tuned vehicles on Dynapack, Dyno Dynamics, DTS, Maha, and Bosch dynamometers. So while the information below may simply be my opinion, I've got the time invested to back it up.
Cliff Notes:
1) Mustang Dynamometers generally read on the low side of the spectrum.
2) We had a Mustang technician fly out here to calibrate our dyno on site after we installed it. I check/recalibrate the dyno monthly during our routine maintenance.
3) I owned and operated a Dynojet for 3 years before we installed the Mustang, and trust me, I changed dynos for a reason (it ain't cheap).
4) The Mustang dyno combined with our enclosed dyno-test cell provides the truest simulation of real world conditions. As such, regardless of how "high" the numbers are, they are more comparable/repeatable and as such are more useful than numbers provided by some other dynos and test cell setups.
5) The accuracy of a dyno and its calibration is about consistancy, repeatability, and correct simulation of real world conditions - not how high the numbers are.
6) I am not knocking those who want to see higher numbers. As with all things in life, you need to make compromises. In upgrading from our Dynojet to the Mustang we decided repeatability, consistancy, and tuning quality were more important than higher numbers.
I purchased the Mustang dyno last year when we decided to move into a larger facility. I decided it was time to upgrade from the Dynojet 424X we had in our old shop for the last three years. Furthermore, I decided it was time to invest in a proper test cell to improve repeatability and testing accuracy. This was an extreme investment in money, time, and engineering - but I got into this business to do the best work possible, not just to get by.
It was well known to me that the Mustang would read lower than the Dynojet. I accepted this knowing that the improvements gained from having a proper load-bearing dyno would far outweigh the marketing power of higher numbers.
What I like best about the Mustang is the integrated eddy-current load cell and the software that controls it. The load cell applies resistance (load) to the vehicle as it accelerates. By entering the vehicles weight and aerodynamics (hp @ 50mph), the Mustang calculates the amount of resistance the vehicle would encounter on the road at a given speed. As such, load is increasing as the vehicle speed increases.
An excellent example of the accuracy of this loading was done during the dyno day. We ran a few of the cars in 3rd and 4th gear - the numbers/graphs produced were almost identicle in each gear. The would not be so on the Dynojet or an insufficiently ventilated test room.
The Dynojet we had before was an inertia dyno. The load was simlpy from the weight of the rollers themselves (~2500lbs each). As such, running vehicles in different gears produced different results. Furthermore, the resistance did not increase as speed increased - unless you are driving your car on glass in a vacuum, that just doesn't equal the real world.
The real benefit of all this really shows when tuning vehicles and when analysing the quality of the tune. With the applied load on the Mustang, you are less likely to get away with a tune that is too agressive or poorly matched to the vehicle. This can be seen in power dips, lumpy curves, etc. On a Dynojet or similar, the lower loads at high speeds usually will let you get off a couple of runs before you see any of this behavior (I found that I had to check/retune some of the cars we ran on the Dynojet).
So, while the numbers may be low, the data it is presenting to the reader has more value. The Mustang dyno combined with proper ventilation and calibration allows you to see how your car is running on the road - not just how your car runs on the dyno.
It can be argued that all this is rather unneccesary if you are just trying to get a power number out of a car, but why go through the trouble of printing a graph if you just want a number
If you guys have any other questions just let me know.
Best Regards,
Dan
I think you made a wise choice in investing in the Mustang dyno. Yeah, it sucks that some of us didn't throw out some huge power numbers on Saturday but I rather have the true power number than some inflated ones. I could have probably squeezed out maybe another 10-15hp if not for the car pulling timing but I should have that resolved when I have the hybrids installed with the custom software.
Dan, you have a great shop and thanks again for allowing us to have our little event at your new location. I will be coming back to you to get a comparison dyno after I get the hybrids put in to see how it compared to my current set-up. Thanks again!
  #184
Old 12-10-2007 | 01:29 PM
Denis GTPRO's Avatar
Denis GTPRO is infamous around these parts
Originally Posted by SCM3
Yes, the numbers do seem pretty damn low. Although Drew's seems to be on par with his previous dyno's, unless his car is a true freak now and makes 500rwhp on a dynojet lol.
I know Dan personally. he is a good guy. He used to have a Dynojet very similar to ours but dumped it because he was having alot of issues with it. Mustang dyno numbers are KNOWN for being very stingy. I seriously doubt that the dyno is off. Harman has plenty of evo and sube buisness, so im not sure complaining is going to do very much with them. Dynojets are the industry standard for HP ratings. When you test on another type of dyno the numbers are always different
  #185
Old 12-10-2007 | 03:10 PM
Bodybag's Avatar
Bodybag has a spectacular aura aboutBodybag has a spectacular aura about
What blows my mind about his Drew's curve is how early the power sees it's max, and then just holds it. Drew's car and mine have very similar components with the exception of different brands of exhaust and different software. We made similar HP numbers too, but mine builds all the way to redline, and his is all-in by around 4750rpm. Could be his race-file and 100 fuel, but I'd guess that his exhaust is outperforming mine and that's where most of the difference is.
It would be interesting to flash my GT2 with a GIAC file and run it again. That would basically make both of our cars equal in setup with the only difference being exhaust, then it would be easy to determine if the exhaust or the flash was responsible for the difference in power.
  #186
Old 12-10-2007 | 03:34 PM
drewTT's Avatar
yeah its a little weird how it flattens out the power.
can you post your graph?
  #187
Old 12-10-2007 | 04:16 PM
Bodybag's Avatar
Here's 2 graphs. The first is my graph, and the second is my graph laid over your's. My car makes power/torque a little earlier, maybe 2-300rpm, but starts to sign off on HP sooner and then slowly builds, while your's goes straight up.
My graph and your's together:
  #188
Old 12-10-2007 | 05:16 PM
mspiredm3's Avatar
mspiredm3 is infamous around these partsmspiredm3 is infamous around these parts
DrewTT, that's a very impressive power curve!
  #189
Old 12-10-2007 | 07:09 PM
bone_doc s4's Avatar
bone_doc s4 has a spectacular aura aboutbone_doc s4 has a spectacular aura about
Drew M3, did you shove a potato in Karl's muffler?
Those numbers look way off bro, weird.....
It was the only way I could beat him!!!!! I'm sorry Karl. Dan went along with it though, he really doesn't like S4's, hahahaha.
I knew I got sabotaged, that would explain why my exhaust sounded kinda subdue during the dyno....
they probably turned the load wayyyy up on karls car. i heard Dan doesn't like stage 3 s4s...HAHAHAHA
You know what, I'm starting to believe that bc I've heard it more than once now....hahahaha
Regardless of the numbers, I had fun with the boys and I'd much rather be 4 door Freeway King than a Dyno Queen anyday.....LMAO. J/K
04-28-2022 12:38 AM
orbelo
08-30-2015 12:26 PM
Rumrunner
Charity Notices/Events
08-20-2015 11:07 AM
Quick Reply: dyno day - who will step up?
