K24/18g vs GT28 turbo
Old 11-09-2007 | 07:22 AM
996Choy's Avatar
996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of
Hi,
I am currently running stock K16 on my car but I'm planning to upgrade my turbos. The 2 turbos that I am looking at are K24/18g from Protomotive and GT28 from SG.
Does anyone know how they compare in terms of lag and top end power? AFAIK the cost is about the same for the 2.
Thanks.
Old 11-09-2007 | 08:13 AM
Dr_jitsu's Avatar
GT28's are superior technology and water/oil cooled. However Todd has had amazing results w/ the 24/18. The big advantage is if you already have 24's then you save a bunch of money, but that is not the case for you.
If cost is the same go w/ 28's. The should last longer and be a little better up top.
Old 11-09-2007 | 08:25 AM
996Choy's Avatar
Thanks. For GT28 does it require fuel system upgrade?
Old 11-09-2007 | 09:16 AM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
They both are better with it. I think it makes a huge difference with the 24/18's.
Old 11-09-2007 | 09:30 AM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Call Todd at Promotive. He did some testing on both and the promotive turbos flowed better whereas teh gt28's dropped off at higher rpms
Jag
Old 11-09-2007 | 10:19 AM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
That's what I was told, too.
Old 11-09-2007 | 10:20 AM
unvmy996's Avatar
what jag said ......
Old 11-09-2007 | 10:58 AM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
I'm in the same exact situation... currently running stock k16's and thinking about upgradeing turbos... to make a very reliable setup for daily driving what parts are needed to be purchased around the turbos? what parts of the fuel system need upgrading?
Old 11-09-2007 | 11:33 AM
Dr_jitsu's Avatar
To get the most out of them look at my sig....you could upgrade plenum and TB too.
Old 11-09-2007 | 11:37 AM
unvmy996's Avatar
jits , are the fuel lines and rail a must ?or can u leave the stockers on
Old 11-09-2007 | 11:54 AM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
My understanding is the Gt28s can be run without the water lines. I may be wrong about that though. If the lines are necessary that is an additional expense you must account for.
Old 11-09-2007 | 12:09 PM
jags911tt's Avatar
Dont forget you must do all the other upgrades too. You cant just slap on bigger turbos and call it a day.
Old 11-09-2007 | 12:34 PM
Ice's 996tt Cab's Avatar
Ice's 996tt Cab has a spectacular aura aboutIce's 996tt Cab has a spectacular aura aboutIce's 996tt Cab has a spectacular aura about
I have the SG700 Set Up. It is awesome!!!! No Lag and the high end is not coming off.
I have the Fuel Kit in the program. Check Signature. If you want teh best go with the SG700.
Ice
Old 11-09-2007 | 12:54 PM
drewTT's Avatar
drewTT has a spectacular aura aboutdrewTT has a spectacular aura aboutdrewTT has a spectacular aura about
i honestly don't think its worth it if you allready have k24s to go to the gt28s or k24/18g if you dont do the fuel system.
you must do teh fuel system IMO
Old 11-09-2007 | 03:49 PM
Dr_jitsu's Avatar
Fuel system made a huge difference....I was barely beating stage 4's w/out it...w/ it I walk by 3 or more lengths in a 60-130 pull.
