New AP/VR 650 Turbo Kit Porsche 996TT
#151
Just checking out some other products out there. Just want to point out some features of the Agency Power AFI 650+ Turbo Kit.
- ALL Made in the USA. Here is Arizona
- Headers are made in the USA with a True Merge collector. Includes dump tubes for external wastegates
- Uses real Garrett GT2860rs Ball Bearing Turbos
- Kit includes water and oil lines
- Tial 44mm wastegates include .8bar spring and produce up to 40ft/lbs more torque then factory internal gates.
- No modifications to fit anything is necessary.
- Tested on 91, 93, and 109 race gas
- ECU Tuning includes flash cable so you can retain your stock map and add a race file at no extra charge.
- Kit is COMPLETELY modular. Meaning if you want to go for more power, spec out your turbo IE: GT3076, GT35R, etc. The manifolds are designed to work with Garrett T3/T4 setups. Just add larger injectors and fuel pump.
- Softronic will do custom tuning for your setup via phone and email if you have your car on a dyno.
Just thought I would remind and share.
#153
Just wanted to share a picture of the Waterlines that come with the Agency Power AFI 650 kit. The waterlines work only with the Garrett turbos to offer both oil and water cooling. Your factory turbo only is oil cooled. These come with our kit at no extra charge.
#160
Dan,
where do you splice into? looks like you need to dill some lines in the water supply aluminum block part? like mine?.... Im interested to see how you guys did it....
2001 996TT 3.6L and stock ECU
#161
No drilling, snippy snip, insert fittings, tighten clamps, and good to go. Of course, best service around, always have pictures on hand
(These are the first sample lines from my car)
#162
Thanks....
looks good,
mark
looks good,
mark
#163
Just took a new product shot of the ENTIRE kit. I want people to see the quantity and quality of parts you get for $10K compared to other options.
- 2 Garrett GT2860RS Ball Bearing Turbos
- 2 Tial 44mm External Wastegates with .8bar spring
- 2 High Flow Made in the USA Headers from T304 Stainless Steel w/CNC Machined Flanges
- 2 Stainless Steel Dump Tubes for External Wastegates
- 2 CNC Machined 6061 Aluminum Oil Cans for OEM style Fitment
- 2 CNC Machined Exhaust adapters to run factory style exhaust with Garrett Turbos
- Complete Water Line Cooling Kit for Turbos with CNC machined fittings and Banjo Bolts
- Complete Oil Line Kit for Turbos with Steel braided lines, machined fittings, and check valves
- 5ply Silicone Couplers to connect Turbo to intake pipes
- Set of TBolt Clamps for turbo couplers to give proper secure fit
- All Gaskets and Hardware Necessary for Kit Assembly
- 5Bar Fuel Pressure Regulator
- Softronic ECU Flash Cable for Loading Custom 650 Kit software. Cable allows you to retain your factory map and make any changes necessary.
