I lost 31 lbs and it only cost $300
#48
These are GREAT batteries, and may well be on my list for the Pcar!
Mike
#49
Mike
#50
Mike, I have been running mine for 14/15 Months (Red Top) now without any issues. Is there a problem with these Batteries?
#51
I had two redtops replaced in my corvette due to dead cells, and two in my other truck for the same exact reasons. I quit buying them. If you can get them to last 18-24 months, you're doing good, mine never lasted past a year.
Maybe I got a bad run, or maybe they fixed the issues they had... This was in the 2002-2005 timeframe.
Mike
Mike
#57
I have had 3 bad ones in 6 years. Not a batch issue. I had it explained to me like this...... if you let them drain and STAY drained for even a couple of weeks without charging.....it kills them quickly. For example....in my Bronco I had a dual battery set up......and something was draining very slowly on my secondary battery......and every time I would need it...it was dead......ended up relacing it several times because It wouldn't hold a charge.......yet in my Mustang.....I have a disconnect onthe battery.......I can (and have) let it sit for 6 months and it will fire right up......but if you drain them and don't recharge them.....they are DONE.
I have kiled Two red tops and one blue top...ALL being almost never used secondary batterys in my 4x4
PenguiN
11-12-2015 05:24 PM
COBB Tuning
11-09-2015 08:02 PM
nlakind
11-06-2015 10:15 AM
COBB Tuning
09-09-2015 09:13 PM
