Can't Pony up for the 650 Kit, How About a 600 Kit
Correct me if I am wrong here but, doesn't Protomitive offer a 650 & 700 kit with the same turbo's just other ancillary items (maf, intake, injectors, throttle body, etc.)?
Don't mean to steal your fire but, I just want to clarify. Kit looks like a nice offering but, subsequent modification and power adders are the root of my question.
so air...intake, plenum, turbo air intake hoses
fuel...5 bar FRP and GT 2 pump, then big time new fuel rails and injectors
backpressure....100cell cats or no cats, headers, straight pipes.
after above you need to go into the engine.
hope that helps!!
Evader my brotha - call the number whatever you want. The same performance is achieved as it is the same parts. If you would like me to buy a dyno jet and start adding 50HP to my packages cause that is what makes people purchase products, I will do so.
unvmym3 - Softronic tuning. Mapping already completed and the great results will be achieved.
sechsgang - looking forward to it!
Is the main difference between your kit and the proto kit the use of External WG's and obviously the headers that go along with them? Do the HP/TQ curves look basically the same or how do they differ?
And lastly are you and Proto the only ones to offer K24/18G "kits" currently?
Nice Work! It's good to see some other options out there...
...stage 4, 600, 700. People have different stage packages that do different things. I do not know what a stage 4 is considered. As far as the Proto package, it is the same components guys. I buy the turbos from Proto. The difference is he includes diverter valves in his package. If you want to call it a 650, go for it If you want to call my 650 kit a 700, go for it, cause it will do the same thing. Just look at the components included. It will get you the same results.
If you were to do external wastegates, you would gain about 30 more ft/lbs of torque and some top end power since you are bypassing the exhaust system on boost.
I love you all... call me directly so I can give you each individual attention to explain differences, benefits, negatives
Thanks for the info Dan. Very cool design!
