East Coast Trackers...vir Mar 08 Pca Zone 2 Event!!!
#286
i could do that..... everyone has a different style,, but the way i learned seams to work pretty well.. but will take a few minuets to jot down... ( i wont include the part about lifting at southbend... i can promise the outcome of that ...you will end up in tire wall at the bottom of the hill) but all jokes aside i can give some hints for 911 cars
#287
I was one of the "lucky" few who actually snapped back and spun into the infield there instead of going into the wall. It is a place where you do NOT want to make a mistake!
#288
#292
Turn 1 come in with hard braking i enter a lil early for a parabolic line through the turn basically on the brakes till apex when hands open i begin applying gas then basically on the gas
turn 2 the car will drift out to the edge stay on gas though turn 3
Nascar bend out to edge of pavement turn in slightly early get on gas for grip
turn 4 slow in slighty early set up well for 5 if done right 5/6 and snake becomes very fast
slight lift entering 7 balance throttle applying more gas as confidence through 8 and 9
( be patient at 7 wait a breath on left side of track before turn in to 8) makes the next turn almost straight line)
hold the car to the inside of 9 staying on gas for grip
touch your brakes before 10 when the car is straight. turn in slightly early here at 10
( do not lift the car will drift to outside !!!)
will set in perfect line for 11
11 turn early right along gator ..straight shot to oak tree)
slow in to oak tree dont be late
turn 14 is mid track turn in use the hill to help brake
get outside to make smooth turn in at 15
car will step out with to much gas here let car drift out shuold be at mid track going into 16 back on gas
i touch brakes to settle front end in the small chute 16 &17 set u well for 17 slight compression stay on gas
set your steering wheel costantly applying more gas to the exit of 17a flat on gas at apex of 17a letting car drift out to gator
take an inside line at the kink! do not lift here!!!! stay ongas and watch for cars entering ot track on left they should stay in blend line but be ready for them not to..
this is what i do .... may not be the same for most but you get the idea...
#293
i didnt have a map so i was doing from memory ... may have missed a few things
be patient after a run or two the track really comes together... just drive 6/10ths and you will pick up speed
#295
All of the new guys are in for some fun. VIR is a great track...
Do a search on youtube for some in car video. That helps a bit. Once you get to the track you're going to be like WTF? So take it easy the first day. You got nothing to prove. Just don't let Ryan pass you. He's the anchor of the black run group. Back at the hotel review the track in your head and then replay the in car videos you watched previously instead of watching ****. The next day you'll be ready to have some fun!
#297
that would be helpful!!!
also first time out we need to line up so guys like me can get the line correctly from someone who knows it.
I'll take guys out with me when I am learning the line but cant do when driving 9-10/10ths
#298
Where we all meeting for Dinner Friday or Sat night. would like to pick at least one night at one place all the 6speed guys could hook up and everyone bring their peeps with them in case we all get into a big rumble!!!!
I have at least 10-15 coming with so I'll be ready, we could probably fill a resturant up!!
so you locals pick the time and place so I can tell my guys.
