East Coast Trackers...vir Mar 08 Pca Zone 2 Event!!!
#376
That's what I do also, and always have done.. The bottom of the pedal near the floor is like a dead pedal anyway, it would take so much pressure its like impossible, side is the way to go!
#378
I do turn my foot a good amount and roll off, but it still isn't the motion of using your heal hah... Been doing it for years and mastered it!
#381
with the TT, you have to be patient as the flywheel is quite heavy...and the gear assembly isnt happy with very fast shifting. However, when you are heel/toeing while threshold-braking, you wont need to worry too much if your giving it enough gas(blip).
#382
its been quite easy so far in 3 to heel/toe b/c the pedals seem pretty close together. it took a lil while to get use to doing it in the 996 gt3 and heavy's 996 tt. but it becomes 2nd nature with seat time in our own cars
#385
werd, I did change mine to metal however as i find that with the rubber *****/sand paper stuff VERY grippy and nice!
#386
MMMMMM..............Pedals.......... (Homer Simpson voice)
I just need to practice clutch out between gears and downshifting multiple gears instead of the mega blip from whatever gear to whatever gear.
#387
there are times thats fine...I just wouldnt go from 6 to 3 or something you know? I do 4-2 all the time as it just saves the hassle...when Im stopping from big speeds though, I like to hit all until 4th at-least...
#388
I dont think I've ever had to use 6th. Where does fifth gear end, what MPH. I've only been up to 171 on the track.
#389
I had to shift at RIGHT around there to get to 6th speed which was at like 174-176 or something and I was only in it till 185...you MAY use 6th at vir depending on how aggressive you are at oaktree...
#390
![Confused](https://www.6speedonline.com/forums/images/smilies/confused.gif)
175mph is hauling the mail!!!
![hilarious](https://www.6speedonline.com/forums/images/smilies/smLach2.gif)
Mike
