Turbo Swap.
Turbo Swap.
I'm planning on taking the turbo's off my car and sending it to IA to change them to the hybrid K16/K24's...
Now my question is, how hard is it to remove the turbos from the car?
I'm assuming that the exhaust needs to come off as well but I planned on getting a new one anyway.
It seems like an easy job but I dont quite know the measurements and want to make sure I'm doing things right.
Also, with K16/24's and a new exhaust, what numbers should I be looking forward to? Also, I'm also assuming the 5FPR is a required mod once I get this install done?
Have you considered UMW ... from what I understand UMW's K16/K24 "Zero Clearance" makes the most power (not to mention the fastest to spool, IMHO) for 16/24 hybrids ... you can see KPG's dyno when he had his ...
https://www.6speedonline.com/forums/...=109067&page=6
I think he had about 512 AWHP / 565 AWTQ and that's on PUMP gas ...
Can some please tell me what "zero clearence" really is. Is it a gap of + .001", +.005, +.020 ??....it has to have some clearence, even if the CTE of the turbine is less than the housing. Thanks
Stephen know his stuff. You should have your ECU flashed. The general feeling is that headers won't mean much as far as power increase. But adds $$$.
You should do your exhaust at the same time saves labor
use new gaskets all around.
MY 03 makes 466 AWD Hp 540 Tq
It has almost no lag, very strong, and runs like a watch!
k16/24 turbos
FVD flash ( good pricing right now)
stock headers ported
GT2 ICS,
Evoms intake,
Forrge diverters.
Fabspeed GEN 3
Good luck
Did you have any MAF issues with your EVO intake (V-Flow) while running your K16/24 hybrids?
k16/24 turbos
GT2 ICS,
Evoms intake,
Forrge diverters.
Fabspeed GEN 3
Good luck
k16/24 turbos
GT2 ICS,
Evoms intake,
Forrge diverters.
Fabspeed GEN 3
Good luck
I took out my EVO V-Flow when I had my UMW Stage II Zero Clearance put on. I was made to understand that the programming will eat the MAF.
What are the differences between the dry and oiled VFlow filters??
I too would like to know if the UMW programming concern is from the flash and combo not liking the increased airflow and hurting the maf or if it is an oiling issue. If so then the dry type filter setup could work. I think it is flow related because Kevins airbox with a BMC is what some run he justs suggests keeping them clean and not overoiling them.
Just to share - I was the original owner of Elliots FVD/Speed Gallery k16/24 kit and I had an EVO V-Flow (the original oiled version) for two years and approx. 30,000 miles with no MAF issues. Daily driver and 25 - 1/4 mile passes - no problems. I believe I also posted the quickest K16/24, 1/4 mile time with this package.
Turbo removal tips:
Remove the bumper and intercoolers for better access.
Spray all nuts down with Liquid Wrench the night before and morning of removal.
Yes remove the exhaust...it will make it easier.
Replace the spark plugs while you are in there.
You do not need to replace any of the gaskets on the turbine. Contrary to what many people on the forum think, they are designed to be reused. So are the stainless exhaust manifold (header) gaskets.
Yes you can keep your stock headers, they are just fine. If you want to improve them, get them ported by a local automotive machine shop (remove the excess welded beads seen in the openings...they should know how to do it without compromising the strength of the weld).
5bar FPR is not usually done with most of the tuners out there for 16/24s. Just ask the one you are using to find out.
K16/24s are a tremendous bang for the buck and perfect for the street and track. If you are not wanting to exceed 500awhp you will have a hard time justifying any other setup.
Port and polish your stock headers. The hybrids from IA are from UMW - thats were Kaspars gets them from. If you want the zero clearance just tell and pony up the extra $$$ for it.
Jag
Jag
Turbo removal tips:
