Serious Gas Fillup problem with my TT
Lately I've not been able to fill the car all the way up without having gas leak out into the plastic hole. Usually its just a little gas that goes through and I just clean it up. But today when the lever clicked I literally spilled a gallon or 2 of gas through the car.
I pulled the gas handle off immediately and there was gas shooting out of the tank!!!! I had to cap the gas tank or it would just shoot out. What is wrong with my car???
Does this happen at the same gas station? I ask because I had a similar problem with my local Chevron. Went down the road to the 76 and was able to fill the tank without incident. Keep me posted, would be curious to find out.
Cheers,
Scott
Cheers,
Scott
My local Dealer (Rector) said that this is a common problem when the breather tube becomes clogged...he suggested hitting with some compressed air, which works 70% of the time, if that fails then the tube is probably kinked and would need to be replaced...$$$.
Had the same problem about a year ago.
Had many people tell me many things. Nothing worked.
Brought it in to dealership.
Here was the deal.
The reed switch was pulled out of the lock. They partially removed the filler neck and reinstalled the reed switch back into the lock.
It worked !!
No problems since.
Total cost: 310.00
Hope this helps.
Ice
Here was the deal.
It worked !!
No problems since.
Total cost: 310.00
Hope this helps.
Ice
Here was the deal.
It worked !!
No problems since.
Total cost: 310.00
Hope this helps.
Ice
Here was the deal.
It worked !!
No problems since.
Total cost: 310.00
Hope this helps.
Ice
Thanks, I guess I will have to make another trip to the dealer
lol
possible hijack - BUT - lately ive only been filling up about 5 gallons worth and my needle is all the way down with the need gas light on - and after those 5 gallons my light is still on, lever didnt move a bit and my mileage left reads "---" meaning no gas.... i dont get it - i filled her up all the way the other night and that worked but only when i fill up a bit it doesnt work
Dave...the turbo has an unusual fuel tank. it has a hump in it and the sensor is in the top part....so the computer estimates the rest of the tank. If you just fill up the lower part of the tank it will not be read by the sensor.
Correct, you have to fill it more then halfway for it to read it.
When I get gas, it fills up and clicks off with no spillage, but if I put any more gas in it spills out all over the ground. However, if I fill it until it clicks, pull out the gas hose and then reinsert it, then put more in, it doesn't spill out. Is this normal, or should I get mine checked as well? It seems to be full when it clicks off, at least the gauge says it is full. However, even when I drive it until the needle is on E I can only get around 14 gallons in the tank, and it should hold 16.6 gallons.
Thanks again!
I have never filled up more than a 11 gallon tank either - even when i thought i was super low - gotta figure out where my limits at
