Car sputters at 3500RMP to 4000RPM
Not sure. I've had the car since April. I've put 5k miles on it and it now has 25k.
Not that unusual really. I had my car in the shop for a few weeks to get the rear bumper fixed after backing into a curb and when I got it back I had the same issues you do. Went to the shop fine and came back sputtering. Changed the plugs (on the recommendation of 6 Speed'ers) and the car was 100% again.
My guess is that while at the dealer or shop they probably moved it around slowly without warming it up and that just did the plugs in. At 25k miles, you need plugs anyway, so just do it.
So, Parktown(Porsche dealer) has had my car for since late Monday. They can't figure it out so they had to call Porsche for help. They think it may be the throttle body, so they're gonna switch it out before they order a new part. Does this sound right? If so, should I expect it to be covererd under CPO?
Not sure if you're asking me if I should have tried it myself, or if your just jackin' the thread. I would think the dealer would have tried this already, but yes, if you're a DIY'er, you should "Do It Yourself."
not jackin the thread...thought the question was relevant to your situation...if it was easy enough to change yourself...why not try that first...this way you can install your plugs of choice
You think? I'm guessing the last thing they want to do is drop the engine. They'll most likely try everything else before incurring that expense.
Cause the car is CPO and this happened as soon as I drove the car off the lot after the clutch change. I wasn't about to start pullin' **** out and messin' with it, besides, i'm not a DIY'r.
I think you'll also be in for a rude awakening on what a "Certified" or CPO covers....lets hope not.
It was the mass air flow sensor. Car runs as strong as ever now. CPO covered. it.
Edit: MAF (for anyone doing a search for this problem)
