If this stuff any good
it looks bling but it doesn't do anything. I've seen a dyno where it added 2hp over the stock unit. You can get more air in much cheaper and better than that... The fitment isn't great from the unit I saw.
Not worth the silly money they are asking for it, unless you are doing the show circuit thing...
DO NOT, I REPEAT, DO NOT INSTALL THIS ITEM!!!!
We had a customer install this...A month later he was paying many thousands for new turbos!!! Problem is it is not a sealed system. There is room for debris to get around the filter and it did!!! Rocks go through and chewed up his impelers!!!
Evan
Evan
Originally posted by luting_chen
this is the first time i see the gruppe m for gt2...
why is it different from the turbo @_@
i thought i should be the same...
Evan
Feelgood MD
03-24-2016 09:35 AM
