Pentosin clutch fluid
The local ex P dealer is suggesting one can use 4 dot brake fluid instead of Pentosin in the clutch system. Npbody was proposing to use Pentosin in the brake system.
I was told my non-assisted clutch system is filled with DOT4, as it was designed for use with DOT 4 and the Pentosin eats the seals on the older slave cylinders. In the absense of such a conversion/requirement, why would you want to use it?
PS- John D's system is not like the factory setup so completely different rules for his setup.
I do not know, but if there is no Porsche dealership near you then you would need to order it from one. Let me know if you have no success...I will ship you a can.
I will buy it buy I have a race this week end and it is dry, cant I use something else just for the race and then I fill it with the right one?? I will need to buy it , please tell me the cost and shipping to Miami where my forwarder receives it
I will go to the dealership to get it tomorrow or Friday. I'll contact my Porsche tech friend and ask if he knows of anything safe to substitute in an emergency.
jaehoppa
10-22-2015 09:17 PM
