I got this 5.0bar regulator from EVOMS, but says 4.0 crossed off... normal ?
Old 12-27-2007, 09:24 PM
porschenaround's Avatar
porschenaround is a glorious beacon of lightporschenaround is a glorious beacon of lightporschenaround is a glorious beacon of lightporschenaround is a glorious beacon of lightporschenaround is a glorious beacon of light
Evoms provided me a 5.0 bar fuel regulator but has the 4.0 crossed off with a marker and written on it 5.0 . Just wondering if this is normal ?
http://www.locodemoto.com/images/4725.jpg
Old 12-27-2007, 09:28 PM
vividracing's Avatar
here is mine. look similar to you? not sure as i dont recognize that mark
Old 12-27-2007, 09:38 PM
Turbo Fanatic's Avatar
does a 5 BAR FPR require a reflash? I assume upping the fuel pressure will up the flow in all conditions?
Injectors are just nozzles that open and close for a certain period at a time.
Old 12-27-2007, 09:42 PM
I would say yes, but there is no need to change the FPR if you are not changing the turbos. When you change the turbos, you need to change your fuel, which then needs new mapping and hopefully the power makes you change your underoos.
Old 12-28-2007, 02:16 AM
DMaffo's Avatar
DMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud of
i got mine directly from neuspeed and it looked like the one Dan posted a pic of.. I freaked out at first coz it was some silly sticker on it and underneath had a 4.2 on it i think it was....but the sticker was 5 bar!!! I was re assured and I installed it! NO PROBLEMO!!!!!! worked out just fine....just a royal pain to get at.... you wont be done in 20 minutes i tell ya!!! But can be done!!
Old 12-28-2007, 02:17 AM
DMaffo's Avatar
id b careful installing it if you have no need for it......
Old 12-28-2007, 06:59 AM
oak's Avatar
oak
oak is offline
why not call them and ask? I''m sure they will respond in a timely manner.
Old 12-28-2007, 07:32 AM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
evoms just crushed a 4.0 bar to make it a 5 bar IT IS NOT A TRUE 5 BAR FPR. Order a real one form board sponsor STRATMOSPHERE. I do not trust a crushed 4 bar. IMO
S
Old 12-28-2007, 07:42 AM
nerdhotrod's Avatar
nerdhotrod is infamous around these partsnerdhotrod is infamous around these parts
S
Agreed. Crushed 5 bars and real 5 bars react slightly different.
Old 12-28-2007, 07:51 AM
oak's Avatar
oak
oak is offline
what exaclty is the diff in reaction? vac?
Old 12-28-2007, 08:15 AM
nerdhotrod's Avatar
Spring seat pressure vs travel. This will create a fuel pressure curve that is has a different boost reference.
Old 12-28-2007, 08:19 AM
nerdhotrod's Avatar
To clarify more, they both with produce 5 bar with out any vac source...the difference is how they react with vac or boost reference.
Old 12-28-2007, 09:00 AM
I have the 5.0 fpr on the shelf like HighHats suggests. If you have questions on the install, my techs can explain, not a difficult job.
Old 12-28-2007, 09:29 AM
DMaffo's Avatar
how much did you pay for it?
Old 12-28-2007, 10:06 AM
al@cpt's Avatar
al@cpt is infamous around these parts
Buy Bosch FPR only, motorsport part number B 280 550 113/2, they usually run about $200.
Quick Reply: I got this 5.0bar regulator from EVOMS, but says 4.0 crossed off... normal ?
