Help with sport seat install
Please help,
trying to install sport seats from a 996gt3 into my 01 turbo and for some reason the power recline function is not working on the driver side. My car originally had the standard power memory seats. Also Im getting an airbag failure. I just took the seat back out and it seems like the wires in the harness do not match up properly, the pins from one side do not match the female side. I thought this was just a plug and play situation. Do I need to move the wires around in the harness?
TIA
TIA
I had the same problem when I installed the sport seats in my car. The negative pins match up, but the positive pins don't. I didn't see a way to move the pins so I just went around the plug for the positive lead. I did this with a splicer and it worked perfect. You still need to use the plug for the negative side, but just splice and bypass the plug for the positive side.
The passenger seat works perfect the way it is, and doesn't need to be spliced.
Did you get the positive from the harness prior to the plug?
Yes, I got the positive from the wire before the plug that is attached to the car itself. I forget what color it was, but it wasn't hard to find.
