Is anyone making 700 crank HP on pump gas?
#61
Correct me if I'm wrong, but if you have the EBC the only thing that triggers boost reduction is exceeding a pre-set maximum boost level? So if the ECU senses knock (let's say from a bad batch of gas) it no longer has the ability to pull boost because that's been ceded to the EBC by circumventing the N75 valve... correct?
#62
#63
I agree, it is nonsense.. I ran my exact same setup without EBC with 1.2 Bar springs (1.1 Bar boost) for 6 months at the Nurburgring and other track/race events, the car ran without a glitch. Something went wrong here. EBC or not, fixed boost or not, these engines at 1.3 bar can detonate if something goes wrong, and they do. Even in ECU controlled boost maps, the ECU does not always have time to pull timing and boost fast enough in case of a problem.
#65
The only thing is does not do is control the amount of boost. So big deal... you have limiter on the greddy and set it at lets say 1.35 bars if you run 1.3 bars max... Your car will never go past 1.35 bars. And if, by any chance, it malfunctions it goes into Turn off mode which basically reverts to your spring rate.... so if your running upgraded springs .. lets say 12 psi.. it will then run in that 12 psi mode... AND your stage XXX from tuner XXX does not shut the boost down either. You will blow it up at 1.3 bars on pump the same way you will on a XXX tuner running EBC... bad gas or whatever... My 1 bar springs I had on my old stage 5 setup running Giac always ran the same amount of boost... pump or race gas.,.... I rather, like I have now, have the ability to run lower boost on pump and higher boost on race gas as tuned per my car.
Its not as "blow up" prone as you guys think.... unfortunately most of you never ran it on 996TTs so you listen to others that never did either... and so the speculation Begins. Yes a couple guys blew the motors running EBCs but it was their fault.... not the tuners. One person ran high boost on pump in cold weather and the other was running blind because he chose not to install the Greddy profec B type 2. So he had no limiter, no warning.... no boost guage except the one on the dash which sucks.
BTW, I have nothing Against running the car without EBCs....
markski
2001 996TT 3.6L and stock ECU
#66
There should not be a boost controller in a stock internal 600-700hp 996.There is no need for it and can only lead to problems. The car should be run at a predetermined boost setting (with enough leeway for temp changes) and be left alone.Build the motor and then run a boost controller.I can guarantee once one pays to do the internals,they will have much more discipline when using it.
.........my 2 pennies
#67
04-28-2022 12:38 AM
BlackMarketRacing
12-08-2015 01:49 PM
turbotuner20v
09-11-2015 12:02 PM
