My Last Big Mod................MOTON CLUB SPORT SUSPENSION
Cary,
I cannot imagine how this could get any better than it already is!! So, what do we need to do?
David,
Seatbelts........LOL Yeah, I know. Actually, I want them out but quite frankly just forgot about them. Who has done this? Is there an upper trim piece that will replace the slotted one that the seatbelt feeds through? I guess I really need to do that, huh??!!
All,
I wish to be VERY CLEAR HERE!! I have not, am not and will not flame the PSS-9's. They are NOT a bad product (although the front spring rates could be a little heavier in my opinion). They are a product made for a particular application. My needs exceeded their abilities, and hence they are not suited for my more extreme application, that is all. They were designed for the driver that wants to slightly lower his car, maintain comfortable ride qualities (while still being a little stiffer than stock) and also have some damping adustability. That makes them suitable for many drivers out there. Do not interpret this thread or my other thread as a flame of the PSS-9's, that is simply untrue.
Britt,
I should be available this afternoon if you want to reach out. Yes, I have been wrenching, and sweating with the heat, for the past two days.
Tim,
Thanks for the appreciation. As you know, our conversations are always enjoyable and I KNOW you appreciated probably more than anyone!! When you are ready, call me and we'll go through all that is necessary. I look forward to your data acquisition post.
David (again),
"Now I really do feel bad for the southern hicks because of the upcoming TOD."
Well, that would have been the case anyway!!! LOL
Andrew,
Ron IS a great guy and he is becoming a very good friend of mine. He is very knowledgeable and pays close attention to the details.
Britt (again),
Yes, I wish to thank Xico as well for sharing portions of his installation. It was what tilted my scale in the direction of the Motons!!
Tim (again),
My rear GT3 swaybar is sitting on my foyer floor awaiting the correct bushings from Porsche Motorsport. I am also waiting for the front GT3 bar and its bushings from them as well! My writeup and accolades were all based on the stock swaybars!! Imagine when the bars go in!!! Whoa, I can't wait!
David,
All,
Britt,
Tim,
David (again),
Andrew,
Britt (again),
Tim (again),
Awesome work. We are all very glad you are happy.
One of the aspects of my job that I enjoy is interacting with people such as you.
Moton from AWE Tuning
Big Mod
Ken,
I'm in the process of switching to the Motons as well(from H&R coilovers). Can you provide a run down of the other components that you used? I noted some ERP parts but I'm not clear on the specifics. Where would I obtain these? Will you be able to compare lap times with this new set-up against the previous? Great right up and very valuable! Thanks!
Tim,
I do not have any concerns about the solid connections. Consider this. The rear suspension subframe is isolated from the main chassis with four big rubber donuts as well. Those are still there, hence offering some compliance. In addition, the rubber connections from the factory, that were replaced as part of this project, were presumably designed in to satisfy the 85th percentile of Porsche buyers. I, and you, am/are not in that category as you know.
I will offer a few more ride characteristics. Firstly, the ride can be a bit jarring over very rough pavement when you are going slowly (like 25-40 mph). Take them fast and the suspension performs very well, as long as your damper settings are proper. Now, the important part, since the car is 157% more stiffly sprung than stock in the front, and presumably similarly in the rear, the car's cornering attitude is very flat. This is so, even with the stock swaybars. Here is the clincher. When the rear tires break free (oversteer), it is much more sudden. You do not have the gradual changing rate of roll angle to assess when the car will break free. I found the tail stepping out on some really tight stuff near my house in the misty rain last night.
Nelson,
Other components....
Rear upper control arms, rear toe link, rear control arm bushings, front control arm bushings.
Nelson,
Ken, did you say that the JICs were double adjustable?
Sharky, where are you getting your car aligned?
For those who dont want to go all the way to motons, JICs are between the Motons and PSS9s. I'm pretty happy with them although I am still playing with the settings.
Cary, can you PM me with contact info please? I wouldnt mind some input on my car. Thanks!
I HAVE BEEN SEE SAWING FROM getting the bilsteins or the JICs after reading sharky's posts (thanks for the Pm) and Ken's outstanding post on the moton's etc. i will be going with the JIC a bit mor eexepnsive but i think it will be worth it, i do not mind having a harsh ride, and for my situation having 18 inch wheels, meaning i have to go a bit low to get the desired effect, i might be riding on my bumpstops if i go with the bilsteins
so it's JIc all the way, i like the motons but it's way over my budget
greta post , great technical info
and great cf group buy lol
cant stop
im ordering more cf stuff today
cant stop
