Sway Bar Question
Sway Bar Question
I know this has been asked over and over. However, what is the real deal with the sway bar situation. In terms of street setup, is it better to run a rear only or both? Then same question but with the track? I am looking into the GT3 sway bars with the GT3RS drop links. Any information would be appreciated. Thank you.
I am trying the rear GT-3 bar first in an effort to dial out the oversteer. Putting in both is a sure cure, but may not be necessary, but not doing it is also probably suboptimal. I will hopefully have data in a few weeks.
I was thinking that both would possibly be a cure, but RUF only uses the rear and a few other companies only recommend the rear. So any definite pros and cons to this or is it just trial and error.
"Putting in both is a sure cure"
Disagree. If you are just trying to get rid of some of the stock understeer, do the rear bar only. Upgrading the front bar can only make the understeer problem worse. There is just no way that a stiffer front bar can help reduce understeer ...
Limitup
Having adjustable bars means you can stiffen or soften. Depending on your whole car, tires, shocks, springs, ... you may need adjustability all the way around. Doing both gives you that so it is highly likely to be the best option (unless at max or min stiffness the bars are under or oversized). It just may not be necessary, as I am trying to discover. If not, I'll add a front.
For sure ... if you track your car then by all means you want the best of everything. However, I have a feeling that the average reader of this board drives their car only on the street, has never taken their car to the track, and has no desire to take their car to the track. These people do not need upgraded front sway bars if they just want to reduce the stock understeer so they can whip out the back end a little every now and then while driving on uncrowded public streets (hopefully anyway!)
By using the REAR bar to dial out oversteer as you've indicated, you will actually have to go with a softer sway in the back. Is the GT-3 rear sway softer (at least on softest setting) than stock Turbo rear sway? I'd be kinda surprised if this was the case.
I have both front and rear GT-3 bars and I can tell you it did remove the understeer. I have autocrossed the car and have done a 4 wheel drift around a corner (wow!). On the track, I can do power oversteer. Understeering is totally gone!
I went from stock to front/rear bars so I don't know the consequences of just using the rear bar only.
Stephen,
Stock car has understeer. I know Tim knows his stuff. I think it was a typo on his part.
On this OS/US note, I have found my new suspension has reduced (eliminated at least on slightly wet roads) much of the understeer and instead I have what some would call "snap over steer". The PSM catches it, but I am hoping the sways in conjunction with tailoring the compression/rebound damping settings will be able to balance it out a little.
David,
That is great to know. I am patiently waiting for my front!! What are your settings at in the front and rear???
Refresh my memory, will you be at Pocono next Friday?
David,
