GT3 Front caliper upgrade
Old 09-01-2010, 05:15 PM
Brad Bedell's Avatar
Brad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to behold
Originally Posted by joeycuccaro
Quick question for you guys... Are the 6 Piston GT3 brakes the same ones off the Porsche Cayenne?
No, the Cayenne appears to bolt from the inside of the caliper (side) and the GT3 bolts from the top.
Look at the photos on page 3 and compare them to the Cayenne.
However, I would like to know if these fit under the stock 996 wheels.
  #77
Old 09-02-2010, 07:42 AM
joeycannoli's Avatar
joeycannoli is infamous around these parts
Thanks for the info. The Cayenne does bolt from the inside, we run them on the S4. I couldn't see the picture of the GT3 setup because it was blocked at work. Make sense, im sure if it was possible people would have done it already.
  #78
Old 09-20-2010, 07:57 PM
Wolk's Wagon's Avatar
Wolk's Wagon is infamous around these partsWolk's Wagon is infamous around these parts
Do these 350mm brake setups fit stock 996 18" twists?
  #79
Old 09-21-2010, 07:34 AM
landjet's Avatar
Yes they do, but just barely. Double check depending on which brand you choose. The 997TT rotors and the Girodisc rotors fit because I have used both under the stock wheels.
  #80
Old 09-21-2010, 09:05 PM
Front and back fit for sure?
Had someone tell me it would not fit with 18's.
Enemy
11-10-2015 08:01 AM
JMon
08-21-2015 08:20 AM
ECS Tuning - VW
08-20-2015 03:07 PM
TrackOne
08-20-2015 12:56 PM
Vrseis
08-20-2015 07:41 AM
Quick Reply: GT3 Front caliper upgrade
