tire diameter difference
what tire diameter difference is ok between the front and rears. i'm considering a front: 25.5" with a rear: 26.3". will that be ok for the awd system - in general what is the biggest difference recommended?
cheers,
boris
cheers,
boris
Generally you dont want to run anything off by more than half an inch. Some guys on this forum say its ok, some have had problems. I believe the manual says something about 4% also. You might want to look into that. If i were you, i'd just run "safe" sizes and stay within a half and inch difference. Good luck!
I've been told by several sources that running GT2 sizes front and rear is fine.
Cheers,
Beej
It's 3.1%. According to Porsche stay within 4%. It's "legal", but I would not do it. Is the car lowered? If so it'll probably rub. Other factors such as wheel offset and fender lip rolling will likely come into play. Keep both ends as close to 25.5" tall as you can.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
horsepowerfarm
09-10-2015 06:09 PM
Mar48
08-24-2015 01:13 PM
