Clutch problem ?
Clutch problem ?
For the past weeks Ive noticed that when I get into my car to start it in the morning and push down on the clutch its very hard. After the first initial push of the clutch it softens back up. Is this a common prob. or is this the start of something thats going out.
01 996TT
01 996TT
Re: Clutch problem ?
[QUOTE
01 996TT [/B][/QUOTE] The clutch system on the TT uses a pressure accumulator system fed by the pwr steering system to assist the clutch. The regular 996 does not have it. The accumulator may be starting to go, bleeds down over night. When you start the car it repressurizes the accumulator and all is good. This may be the worst you ever see- i wouldn't worry about it much for now unless the clutch starts to remain hard maybe as much as 20 seconds AFTER starting the car.
Anyone with a TT can feel what you are feeling by shutting the car off on level ground and pump the clutch 3-4 times and it will get stiff. Restart and all will be as before. If it should get worse in future and you must make repairs, there IS a retro fit to non accumulator type. Seth.
I would run it up to the dealer. I have had 5 of these which all fell under a line issue. Originally it was a TSB then went full recall by DOT. Call your dealer and ask them about Recall 01V015000. If the car is driven daily it should not lose pressure like this under 24 hours.
Seth, We modified 1-2 TTs a month in house. Sometime more, on the good months Lord knows how many ECUs, Honestly I have lost track.
jaehoppa
10-22-2015 09:17 PM
ECS Tuning - VW
09-03-2015 09:43 AM
