jack points
it has also been said that you can jack from the bottom motor seam with a block of wood across the length of the motor. there are a few good DIYS on the forum which also point out in detail the jacking points and what to look for. dont forget the stands.
I was able to get the rear of the car up on blocks using the OEM tire changing jack, if that is what you are trying to do...
With the car at full height on the front jack point, a piece of 6x6 PT, (2) 3/4" thick pine boards and a hockey puck slipped right in at the rear jack point Joe was referring to. You can do one side, then the other. And the wood makes a very stable platform.
fjwheeler
09-19-2015 10:56 AM
