Mr. Clean Drip Dry wash system
I have used it but I still dried the car. I figured it would take care of whatever I missed and came out of the seams.
What I did not like was how weak the water spray becomes when you run it through the filter. It is like a mist and the unit is big and bulky. I do not use it anymore.
You guys, I've never used the soap to really wash the car. It won't clean the car by itself, the only real use of it for me is the filtered water part. Just do the actual washing by hand with whatever soap you'd normally use, then rinse with the thing.
I'm going to put a similar system together tomorrow using parts from Home Depot. Get a GE Smartwater home filter system and use a .5 micron filter or lowest equivalent (good enough for drinking water). I'm going to add a two way tap and some quick connects. Probably cost $40 and last for many many car washes
I am not sure that the GE smartwater systems will work the same at getting rid of the minerals in the water. Theres more then one thread on this over at autopia.org but if i am not mistaken the filters by themselves will not take out the "hardness". You either have to do it chemically or electrostatically (think thats the process). I have been meaning to call my water filtration rep to ask him how i could do it at home, but i havent gotten the chance as of yet.
Power washer absolutely! Mine has adjustable everything. No problem with the paint if the pressure is gentle and the pattern is a fan-out. Very handy in the cold when you want to get rid of the road salt and dirt but don't want to touch the cold water.
Now if I can just spread and let it dry without the towels, it'd be really "hands free" from a water stand point.
Originally posted by Soon2be993tt
I've used it, and didn't like it that much. But i'm a perfectionist. I'd rather hook up one of those portable soft water units to the hose.
Even when my car was black, it only took me 20 minutes or so to wash it to perfection. What are you doing that it takes you an hour?
