Simple and Easy 996 TT OEM SEAT Mod
Ok always hated my OEM TT seat, so bought a GT3 Seat which was fine until my nephew gave me a back problem on a water slide and since then have been always twisting a nerve so GT3 seat unfortunately had to go (and I'm much the better for it, however I loved it; as daily driver it just didn't work). So back in with the OEM version (electric everything, including all the little air pump bags.)
Two weeks later I really hate OEM again, its like sitting on a SOFA in a 500 HP car, the seats just don't grip and have been racking my (small brain) deciding what to do about it whilst desperately holding onto the steering wheel.
Today I discovered that you can un hook the OEM seat center section, Pic 1 yes, just lift it up and it angles forward. So I simply took out the large formed dense foam in there Pic 2 (which can be then reinstalled as you so wish) and fitted it with a cut piece of less dense thinner foam (already fitted in Pic 1)
Now I have a sports seat again, which I sit in, not on and the sides grip. This very simple mod has made me extremely happy.
Electric everything works just the same of course
Could be the answer to my prayers! Thanks!
I have been keeping an eye open on used Sports seats prices and they are just a bit too prohibitive, and next to never in Stone Grey.. I hate the roll off feeling you get on stock seats cornerring fast, looking forward to getting home tonight now to mess with mine!
How thick foam did you go down too? Still plenty comfortable too I take it?
With the new foam, I just cut out the same shape from a foam square bought from my DIY store, its slightly less thick than the OEM foam you take out but more critically is much less DENSE which allows you to sink into the seat and take advantage of the side grip, its a massive improvement
The backs come off easy enough, did you wiggle in/out the foam or unlip the fabric from around it to get it out?
Hopefully I'll get a chance to find some suitable foam replacement this weekend, gueesing at the fabric/sewing shops...
top center section only, I separated the grey foam from the main support cushion (pic 2) and the inserted the new portion. Ps you need to re use the white plastic frame but I took out the metal rings previously attaching this
Those rings are little buggers, so you just went without them I take it after the mod? Get in there with a couple of needle nose pliers to pry them open or something more crude? Your tips would help, thanks in advance!
Sorry if i missed this, but where did you get the foam replacement? Thanks!
