Vivid's JIC Cross Suspension Package (Pic)
Old 02-27-2008, 04:11 PM
vividracing's Avatar
that picture shows the OLD droplinks. The new drop links are on post 1 laid out on the table in black. never broken those.
  #47
Old 02-27-2008, 08:20 PM
ldc's Avatar
ldc
ldc is offline
ldc is a jewel in the roughldc is a jewel in the roughldc is a jewel in the rough
Correct if i'm wrong but those pics of the OLD droplinks also show how they were connected to the OLD JIC setup....new setup they connect elsewhere right?
dc
  #48
Old 02-27-2008, 09:57 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Do the JIC transmit shock/spring noise into the cabin. I'm only considering these for street use. There doesn't look like there is much in the way of sound isolation in the top perches or mounts. I'm still trying to decide between the PSS9 and JIC.
  #49
Old 02-27-2008, 11:08 PM
jon@jic-magic's Avatar
jon@jic-magic is infamous around these parts
make sure corrct install by Porsche specialist not euro car specialist. when install is crrect dosen't make shock/spring noise into the cabin. past two year new version drop link we did track durability test proved with lap time , street durability test proved.
I attached drop link install photos and our demo car photo.
Old 02-28-2008, 12:12 AM
Can you explain( I actually don't know) why one side has 75 mm and the other 70 mm written?
thanks in advance ,
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
  #51
Old 02-28-2008, 12:22 AM
both side 75mm is fine. this position dosen't make stress for drop link. depending.ride hight will change little bit position change.
  #52
Old 02-28-2008, 08:42 AM
hey jon! Thanks for posting. you can really give some good insight for the JIC owners.
Dan
  #53
Old 03-04-2008, 02:13 PM
blakt out's Avatar
blakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond repute
Originally Posted by Robert@Redline
Sure:
GT3 front a-arms and brake guides. GT3 Cup rear lower control arms and GT3 rear brake ducts guides. GT3 rear subframe solid bushings. Rear TRG toe link with OEM front turbo tie rods. OEM 993RS engine mounts.
The GT3 front a-arms allow more camber adjust with the correct caster placement of trailing arms. OEM GT3 rear subframe bushings reduce movement of rear suspension and they are much cheaper than any aftermarket offerings. Rear GT3 Cup control arms allow more camber adjust, has solid inner bushings and trailing arm bushings. I choose TRG rear toe links for the build quality, they are needed because of the extra adjustability of rear toe. They also eliminate needing to adjust toe with the OEM eccentrics which is a joke. And finally, 993RS rear engine mounts. The 996 turbo powertrain is very heavy, we have found when tracked...the stock engine mounts would allow excessive movement causing the rear move. When we tried the 993RS mounts, it made a huge difference.
Dan,
Awesome setup, man! So good. You're really making an insane car out of what was already a monster! Can't wait to get back home and follow you around the track.
As for Robert's comments and suggestions, I do fully agree. I have all this stuff on my car (albeit 997S) and it's all made a huge difference. I have a different brand on a thing or two (GMG instead of TRG drop links, for example) but the whole setup is spot on and just allows for more suspension tuneability. You asked if you'd have to have it set up again, yeah. You would. Adjustability is the reason that you do these things, actually. Remember my ranting over how wonderful a thing camber and toe was? That's from some of this stuff, such as the control arms and dog bones. But I would suggest taking it one step at a time (or in chunks, like you are) so you can appreciate each dollar you spend instead of not really knowing what to appreciate. Do a few track days like this and then do the rest.
Oh, and the adj end links DO make it easier to adjust the GMG sways while at the track. Remember how I had to change mine like 5 times that one day at CMP? Being able to adjust the end links helped a bit. Just a thought. That's not really their purpose, but it helped release the bind.
Peace out bro.
  #54
Old 03-04-2008, 08:25 PM
Hey man! Hope your world boarding adventure is going well! Cant wait to see pics and hear stories. Your 997 will be a beast when you return. The car Robert did with all that suspension stuff is my buddy Jack that we did a 650 kit on his car. Its a monster, alittle over the top for a street car, but that is how Jack likes it. For those going to TX2K8, you will see this car in person! Weekend DE guys can stick with my package, maybe if you want run the GT3 front and rear sways.
Good news though... We just finished testing our Agency Power prototype rear 25mm adjustable sway bar. Details coming soon So track junkies who want to test this out, get in line
  #55
Old 03-04-2008, 08:57 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Dan
I hope you bring all of this with you, I am looking forward to seeing these items!
Cheers
Robert
  #56
Old 03-05-2008, 08:49 AM
I will be bringing alot of sweet toys
  #57
Old 04-08-2015, 09:09 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
Originally Posted by docdan
Hi all,
I just wanted to share a picture of some of the parts I just received from Vivid Racing. I ordered the 996 Turbo Suspension package which included:
1. JIC Cross Coilover suspension
2. Agency Power Adjustable Rear Control Arms
3. Agency Power Rear Sway bar links
4. H&R 24mm rear adjustable sway bar
As you can see from the picture, the build quality and precision of these parts are apparant. Check out those camber plates! I had these installed by Doc's Grrrage in Lexington, SC and had it aligned and corner balanced by the good folks at Autometrics in Charleston, SC. They were impressed with the build quality as well.
I have yet to take possession of the car, but Autometrics set it up to the same specs as their Porsche Cup Car. I also upgraded my rotors to the Porsche GT3 Cup Rotors and Pagid Yellow pads. I am running GT2 calipers on the front and stock turbo calipers and rotors on the rears.
One controversial piece of equipment in the whole package is the front droplinks. As you can see in the picture, they are not as beefy as the rest of the components. Some 6speed members have reported breaking their front droplinks.
Dan from Vivid Racing has been very helpful during this whole process. He has reassured me that none of his customers, inlcuding himself, have had these droplinks break. Nonetheless, in 30 days, he will have available to me some new heavier duty droplinks to replace the ones above.
Thus, apparantly the fly in the ointment has finally been extracted. I can't wait for my next track day. The folks at Autometrics assured me with the new suspension and brakes, the car will perform like a whole new beast.
I will keep you guys posted!
Does anyone know why the camber plate is straight with this system? I thought RWD was straight and turbo AWD the camber plates are angled 30 degrees or something like that? With the camber plate beign straight, it's still ok with the awd uprights?
04-28-2022 12:38 AM
COBB Tuning
01-29-2022 09:42 AM
Michael_s
09-11-2015 08:03 PM
08-21-2015 09:56 AM
Quick Reply: Vivid's JIC Cross Suspension Package (Pic)
