EPL Tuned K16/16G RESULTS!!! (warning, long)
#61
So are these 16K/16G turbos a good setup for me ???
I currently have a K16 with exhaust and Dvs. I don't want any rebuilt internals. I just want a 600hp car that responds/drives close to stock - no extra lag.
Is this a better option for me than some of those bigger Turbos ??
#63
Then there's that other type of joy when you mash the loud pedal .
I'm finding it very tough to describe, but even if the car made the same power as stock, I'd still want Tony's software just for the throttle response improvement.
#64
I'm down for that Alan, btw hope all is well over in the Jers
Seal Grey i'm down for a dyno/run day for sure.. But I would also love to just get together and chit chat, and get a ride with your new setup if you don't mind I'll let you take mine for a ride, although it's pretty useless in this cold temps LOL!
Do you guys know if it will be OK to post up about this on 6speed? The shop that will be hosting this event is not a forum sponsor. I will not be making any money form this event but I would like to organize it. All results will be posted here for the forum members to enjoy. I just don't want to get BANNED if I try and put something together...
How does March 8 or 9th sound to you guys?
#65
March 8 = wedding day.
I'm not definite, but I'm pretty sure if I attended, the bride-to-be would show up with a shotgun and haul me out of there.
Then I'm on my honeymoon until March 27th.
#66
BTW Alan, I think you should be good to go posting it up!
#68
General rule of thumb for good tuning practices is that injectors should not be pushed beyond 80% duty cycle.....well, its seems these good practices are often over looked by many, if not all tuners in the European tuning market ( this is not a shot at any tuner, I find myself doing the same day in and day out).
Seals car is currently running ~96% duty on his injectors. Basically what this means is that the fuel injectors is spraying 96% of the time. This type of fuel delivery is not much different then carbonated fueling technology where fuel is just “ON” at all times..
I have data logged many 996’s at this point with various set ups and I often see theoretical injector duty surpass 100%. Anything above 100% is 100% and the fuel injector is just a wide open fountain with no control…
I think the biggest thing that needs to be considered when approaching nearly 100% the capacity of a fuel injector is this….The me7.8 ecu is very very solicited with many safe guards. The ecu’s ability to enrich the a/f mixture based on conditions that it believes are not correct is one of its simplest yet most effective safe guards of them all. For this reason Porsche built plenty of over head into the 996tt’s fuel system. When we chip our cars or add turbo upgrades with out increasing fuel capacity, we are removing some of this over head in the fuel system and taking away a considerable margin of safety.
5bar fprs and bigger fuel injectors are cheap… 996 motors are not. Over head should be kept in these fuel systems when at all possible.
#69
Every tuner will tell you something different about when/if you need a 5 bar on these tunes.
I think the biggest thing that needs to be considered when approaching nearly 100% the capacity of a fuel injector is this….The me7.8 ecu is very very solicited with many safe guards. The ecu’s ability to enrich the a/f mixture based on conditions that it believes are not correct is one of if simplest yet most effective safe guards of them all. For this reason Porsche built plenty of over head into the 996tt’s fuel system. When we chip our cars or add turbo upgrades with out increasing fuel capacity, we are removing some of this over head in the fuel system and taking away a considerable margin of safety.
#70
Average $550
2001 996TT 3.6L and stock ECU
#71
335 for 6... but keep in mind you will need software that supports whatever injector you decide to go with.
#73
Opps, I missed seals response. Good thing we said the same thing .
#74
For those interested... This is the absolute end of the stock fuel system. Sure, some will chime in that "I made more with out bigger injectors"... But from a good tuning prospective, anymore power then this should really have bigger injectors.
Duty Cycle graph for reference.
#75
Nerd, following the logic you posted above, and seeing Seal's graph, it looks like the limits have already been reached above 5K rpms and that the ECU has little control of the fuel mixture above 5K rpm with this tune. Or does the ECU continue to adjust the AFR through other means once it knows the injectors are no longer regulating the flow?
Correct. The car really "need" fuel injectors. On seals car the ecu only has the ability to richen up another ~3-6%. Which isnt good, but its better then ALOT of other tunes I've seen on the market.
If the ecu thinks things are REAL bad, it will close the throttle body and release boost pressure (as long as you dont have an electronic boost controller).
