EPL Tuned K16/16G RESULTS!!! (warning, long)
Old 02-17-2008, 03:03 PM
Seal Grey Matte's Avatar
Seal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to behold
I don't think the issue is whether or not you have a five bar, it's whether or not the car is tuned to take advantage of the 5bar.
The program should be specifically written to take advantage of the extra fuel, if not, you're better off leaving the stock FPR in there (unless the tune is running lean).
  #92
Old 02-18-2008, 01:35 PM
audikp's Avatar
audikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to behold
Originally Posted by Seal Grey Matte
Thanks man! No excuses now... when are you picking up the 996TT? I'm giving some thought to doing some fab work on the stock exhaust and installing electric dumps. I could use your input.
i've started looking....so we will see.
As for your exhaust...I say you mod the stock before spending $$$ on a Milltek or other. Worst case - you're not happy with it, sell it, and buy Milltek or other.
The dump is also a good option. I have them on my S4 and they have proven to add power...not to mention change the entire sound of the car, maybe a bit more (volume) then you'd be looking for...
  #93
Old 02-18-2008, 02:21 PM
iLLM3's Avatar
As iv'e posted before when I was interested in doing the same, the exhaust cutout/dump valves seize up due to the eat in the rear from the turbo's/motor!
  #94
Old 02-18-2008, 02:27 PM
audikp's Avatar
well there is always the manual / non-electric valve system....seeing as the exhaust is so accessible on these cars...
  #95
Old 02-19-2008, 02:57 PM
StrtSwpr996's Avatar
StrtSwpr996 is infamous around these parts
What else would be needed other than a 16g compressor wheel to make this fit on our stock K16 turbos?
  #96
Old 02-19-2008, 03:33 PM
Mikelly's Avatar
You guys keep me posted on the time and date for the dyno day and I'll see if I can make it with my "old" K16/K24 hybrids and UMW tune. My car made 510Whp & 532# torque on 93 octane and stock wastegates and the 3.8FPR with an Upsolute tune on a Mustang Dyno (AWD), and I'm expecting more with a better set of afrs and IDCs.
Mike
  #97
Old 02-19-2008, 03:51 PM
We'll definitely keep you in the loop Mike. It'd be fun to put a name with a face. Plus, I wanna see you do those wheelies in person.
  #98
Old 02-19-2008, 05:59 PM
Turbohead's Avatar
Turbohead is just really niceTurbohead is just really niceTurbohead is just really niceTurbohead is just really nice
For starters, it made 30 more hp at the wheels than a car that had ALOT more hardware (intake, exhaust, ICs, headers, etc.). I liked the curve a lot better, too. Here's the plot from the K16/K24 car at the east coast dyno day:
https://www.6speedonline.com/forums/...3&postcount=42
Ok i'm convinced . Tony I got a 5 bar to put in..... as you suggested and i'll call you to clean up my tune. It will be interesting to see how much it improves. Thanks for the heads up Seal grey !
Elliot
  #99
Old 02-19-2008, 07:15 PM
Tboy911's Avatar
Tboy911 is infamous around these parts
Hey Tony , have you tuned any k24/18g cars yet? if so what were they puting down?
Tommy.
  #100
Old 02-20-2008, 03:11 AM
deandob's Avatar
deandob is infamous around these parts
Tony, for wastegate upgrade, what do you use (separate wastegate or upgraded springs in the factory actuator)?
  #101
Old 02-20-2008, 06:19 AM
For wastegates, the stock actuator and rod are completely removed and replaced with a brand new actuator with a one bar spring inside and a thicker actuator rod. These are also manually adjustable to set the crack pressure equally. It is similar to the upgraded actuators that EVO sells.
  #102
Old 02-20-2008, 10:53 AM
nerdhotrod's Avatar
nerdhotrod is infamous around these partsnerdhotrod is infamous around these parts
Hey Dean. I shot you an email.
  #103
Old 02-20-2008, 02:27 PM
deandob's Avatar
Got it, thanks. I have responded.
  #104
Old 03-25-2008, 04:22 AM
zaverdin's Avatar
zaverdin is infamous around these parts
WOOO...Impressive numbers....congra guys!
  #105
Old 10-21-2009, 06:23 AM
XLR82XS's Avatar
Originally Posted by KPG
Seal Gray. Just to correct the record and certainly not to take away from your great numbers but your info isnt correct. My car was run on an AWD Mustang at Wheel to Wheel Powertrain in Troy, MI. IT was 12gal 94 and 4 gal of 104 mixture running a pump file at the aforementioned 1.25 bars with a Miltek with a stock 3.8 FPR
Anyway, congrats on your setup and dont worry about all the experts around here. It is your money and your choice and if you're happy then I'm happy for you. Go get some 60-130's for another comparison. Have fun
A very good friend of mine worked at wheel-2-wheel before they closed.
04-28-2022 12:38 AM
BlackMarketRacing
12-03-2015 10:46 AM
Sales@epl
996 Turbo Vendor Classifieds
09-07-2015 02:05 PM
Vrseis
08-20-2015 07:41 AM
Quick Reply: EPL Tuned K16/16G RESULTS!!! (warning, long)
