Spark Plug Replacement Question
Denso Plugs - PK20PR-P8 (double platinum )
and the link http://www.sparkplugs.com/results_cross.asp?pid=3245
John, I watched Tom @ Lucent change my plugs and the coilpacks can be tricky getting out and back in. He said to be careful with them and not to pry them with a screwdriver.
Thanks for the tip Mike and the pictures, Danyol. With 3 feet of snow on the ground, I have nothing but time right now, so I will be patient. If I get in trouble, I have a tech that can make house calls :-)
Start to finish took me 4.5hrs and I spent time cleaning the intercoolers and anything else that looked like it needed cleaning.
You will need a 1/4" drive with a swivel, and approximately 12" of extension and a 10mm socket to reach up and remove the rearward nuts on the inner heat shield. The forward nuts can be accessed after pulling the intercoolers.
Everything is just R&R.
Careful with the hex bolts on the coil packs the heads can strip and removing them can be a PIA after that. Otherwise small hands and the tools mentioned help. I did not remove the heat shields, just bent them out of the way and installed the Denso Iridiums. Do a search on the gap, I remember reading the gap quoted in the manual is too wide.
The plugs come ready to go pre gapped correctly...
2001 996TT 3.6L and stock ECU
My Bosch FR6LDC were gapped correctly.
Edited to add: Always verify gap @ .8mm (.032")
.025-.028 for cars that are ~600 crank+.
