Dyno Results :( Stage 4GT
#61
Originally posted by sharkster
Funny you noticed that. I get that same feeling. Almost like it's pulling timing or something. However, I'm running really rich too... and not boosting all that much (1.1/1.2). Could be the hot weather or some other problem with my car.
I've also never had any issue with hot weather. The car runs great when it's 110 or higher, which is about 3-4 months out of the year here. In fact, in the first two months of the stage 4gt upgrade, I don't think I ever saw ambient temps below 105 min.
It's back in that 110 range again and I still have no issues. No change in boost. The car feels slightly slower as I would expect. But, it runs fine. Just like the first day of the install.
Maybe the issues are more to do with various custom parts you guys are running? I went with the off the shelf 4gt package. I did not want to try anything that Todd hadn't already flogged himself for many miles for fear that even seemingly minor differences from the basic package could lead to problems what would require custom programming (which I didn't really want to get into).
#62
How can you spin all 4 wheels into third and not spin in 1st and 2nd? Could the clutch be slipping? A stock GT2 is nearly as fast and that does not spin even 2 wheels. My Ruf which does 128 MPH in the quarter will occasionally spin all 4 in 1st, very rarely in 2nd and never in 3rd.
#63
Originally posted by Bill S
My car looses power at 5500 and then picks up again. This is a limitation of the engine with low octane fuel. If you use 100 octane and re-train the ECU, this will mostly disappear, unless you are running very high boost.
So, you guys are running the 91 octane program with the pump fuel right? As opposed to the 94 octane program?
#64
Originally posted by racer63
Sharky,
Sharky,
#65
I have never had any clutch problems. I upgraded the clutch at the same time as the 4gt was installed.
Also, the car will not spin the wheels in third in warmer weather. A slipping clutch would not be dependent on the ambient temps.
#66
That is correct. I do have a bit of a mish-mash of different parts. The big difference is the Turbos. I do at some point need to get fine-tuned for that if possible.... As it is I'm getting high 9 low 10 AFRs
#68
Mike
#69
Dyno Dynamics are an Australian dynomometer. They read 17% less than US machines (a la Dynojet and Mustang). They also have a roller speed limit of 200 kph, so that's why you can't always use your 1:1 gear for the dyno pull.
Read here for a more detailed discussion about the 17% difference.
In the end, a dyno is only a very useful tuning tool. Bragging rights are a misuse and are not going to be apples to apples.
ModBargains
BMW Vendor Classifieds
10-13-2015 03:46 PM
ModBargains
10-13-2015 03:45 PM
ModBargains
10-13-2015 03:43 PM
ModBargains
Bentley Vendor Classifieds
10-13-2015 03:42 PM
