Front Tire Size - 255/35/18?
Originally Posted by HotRodGuy
i'm actually still running the 295/30 in the back. But the 255/295 sumo's match exactly.
Got tires mounted today, have them back on the car, but haven't dropped it and driven yet
It looks like a good chunk of your summo tire is poking out from the front fender. From that rear shot looking forward. One pic from directly overhead of the front looks like the rim lip is poking out from the fender.
Your not worried about sand blasting your paint from the front fender back?
nope....was running between a 10-15MM spacer on the stock wheels. I drive the car a lot, it's gonna get some scratches and such. I'm not holding onto it for resale value.
I think once I do the radiator bracket trimming, that I'll run a 10MM spacer on these too.
i'm very happy with it, turn in has improved pretty significantly it feels, but I'll be honest to say I haven't gotten "crazy" with it yet.
To sum up the info i got about the right offset for a 9" i can say, that an offset of ET 47 would be to agressive. Maybe when you role the fenders it will work.
Probably i should do it anyways.
I guess an offset of at least ET50 or higher will be better. No clue how much space is left to the inside.
If anyone got the perfect ET, let me now. Thx
![Wink](https://www.6speedonline.com/forums/images/smilies/wink.gif)
