Front Tire Size - 255/35/18?
#31
Offset depends on if you're rolling fenders or not as well as how much camber you're going to run. A +45 will fit with ease with rolled fenders. I have +40 9 inch with my 255 and actually run an 8mm spacer as well as have a essentric lca tgats pushed out 3/8 inch over stock running 2.5 camber and could even move it out further. If you're willing to roll fenders you gain a lot of room.
#34
Thx guys,
i guess the best tire for me will be the 255/35 cause its smaller than 235/40 diameter wise (around 10mm). Thats alot. I will use Yokohama A052 tires cause i can go the 996 GT2 size or the 255/35+295/30 route.
Lets see what will peform better on the racetrack.
![Wink](https://www.6speedonline.com/forums/images/smilies/wink.gif)
#35
Thx guys,
Lets see what will peform better on the racetrack.![Wink](https://www.6speedonline.com/forums/images/smilies/wink.gif)
They performed really good. The track got dry later so i could run some fast laps.
the grip over the tt standard is hugh.
245 or 255 would be even better.
Well lets see which tite is available next year.
#38
![](https://cimg6.ibsrv.net/gimg/www.6speedonline.com-vbulletin/2000x1504/3d86b9f7_1af6_44ae_9a4d_701db2595a8b_07c5dd4de6403f46a3777dde472ec4f37bc4a237.jpeg)
![](https://cimg7.ibsrv.net/gimg/www.6speedonline.com-vbulletin/2000x1504/361fbf29_6576_4ad0_bc39_19fd3a5c0625_3a1e4880233e0c6f35c08b5a7fcb9c0bbdf39578.jpeg)
A little more fun without curbs and astroturf cause of the wet track before.
https://youtu.be/lf_TAQomEec
My 235/40 isnt rubbibg with 8.5x18 Offset 40 rims. There is 5 mm spacer between fender and tire when compressed to the fullest.
Could get tricky with the 245/40.
witz 255/35 there will be more space cause the tite is in diameter smaller
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
ModBargains
Audi Vendor Classifieds
09-01-2015 05:26 PM
ModBargains
08-20-2015 12:28 PM
