K16, K24, and Hybrid People - New Product For You
For those customers running the turbo kits from other tuners that use stock style hybrid turbos, we have listened to the requests and worked with AFI Turbo to release External Wastegate headers for the stock turbo fitment. All these companies offer great turbo upgrade options that MANY of you have. Some of you have suggested interest in upgrading from the internal wastegate setup to the external setup with Tial 44mm wastegates. Only to add on to your already dialed and happy setup, this is a new product to check out.
Feb. 21, 2008
"AFI Turbo has released their all new made in the USA stainless steel high flow headers for Tial 44mm External Wastegates. Engineered and designed to fit all 01-05 Porsche 996TT cars. The headers feature CNC machined 1/2 inch thick flanges with a "true merged" collector. V-Band clamp flanges are welded on the header and included dump tube for a clean and easy installation. The Wastegate tube is placed just off the side where proper exhaust flow will activate the Tial Wastegate without any boost creep. The headers are made from 8gauge 304 stainless steel. These headers fit stock style turbo configurations including: K16, K24, and other hybrid turbos. The turbos fit to the headers using factory hardware and gaskets. The kit includes hardware to block off and keep closed your factory internal actuator flap.
As tested by Vivid Racing on a K16 turbo car, these headers made approximately 40 ft/lbs of torque more then the stock style internal wastegates. By bypassing the exhaust system and dumping the exhaust gas straight out of the headers, a large amount of power is picked up.
Note: The factory boost solenoid cannot control external wastegates. You will need a boost controller or you can run the wastegate spring boost of about 1.0 bar. Tial Wastegates are supplied with .8bar springs."
Feb. 21, 2008
View YouTube Video Here - http://www.youtube.com/watch?v=EcS0Cg8gDao
Product Link is Here - http://www.vividracing.com/catalog/a...5-p-47137.html
WOW, i think that is one of the nastiest things i've heard in a while.
Those Manifolds look good!
External wastegate can improve power/torque. When an internal wastegate opens its exhaust gases impede the flow of the turbine exhaust. This negative effect varies by design of course. In some systems it is negligible while in others it is significant. An external wastegate can eliminate interference with turbine exhaust flow as long as it enters the exhaust system far enough downstream of the turbine. In this design, it vents to atmosphere so the turbine does not have to share any of the exhaust system with the wastegate gas. This is race car stuff, the drawback being that it is not street legal for noise or emissions.
Awesome product offering!
My mod list priority just changed.
I went from internal to external gated dumps on my EVO and the change was definetly seat of the pants improvement.
I will be picking up a set of these soon.
Question:
Do you offer this as a comprehensive kit?
(Header gaskets, wastegates (looks like they are included), and any misc tubing/hardware)
Question:
unvmym3,
I inquired about this on my Proto 700 package a while ago and I was told it would not make any difference in the performance of my car. I am far from an expert on wastegates, but my inclination is to agree with Kevin on this...
Kevin you were mentioned in a positive way... I made sure of that. Never seen a proactive post towards us??? You want to test the product, no problem. Just like when I called you for a clutch for a customers car that referred me to you and you gave me retail, feel free and click that link to buy.
Everyone else here thank you for the comments. Any of us that have run Japanese cars knows what an external wastegate does. Like Roasterdoc said, when the factory internal wastegate flap opens, it opens RIGHT IN FRONT of the turbine wheel blocking exhaust flow. Again, this is just some old school concepts being brought in a new school way.
