whining noise
low Pentosin or the Belt
My Alternator has just been replaced, common that the bearing inside can become worn and noisey or pulley's can be out of alignment. If pulley's you can buy belt spray or go old school and try and rub a piece of chalk on the side of belt when running, it will help you identify the problem.
Kung seryoso ka ... may mga kilala ako. How about flash?
Ari, I understand a bit of Tagalog but originally from Australia. Have been here for 14 years and pretty well will stay here for along time. I have the Softronic flash and very happy with it. Know anywhere in SFO that I can get the Steer Oil reservoir for a good price? I will be in SFO on the 3rd of March for one day.
Where in SFO? I suggest purchasing it from Suncoast Motors and and have it shipped to the hotel that you're staying ... or I can hold if for you ...
Also, you considering taking the suspension with you as you fly back? or just having it shipped?
Just checked. It is definitely the Transmission Oil Reservoir. Filled the Oil up and dis the check again and it whistled. Is it safe to drive or should I change as soon as possible. Can anybody help me on when I can get a new one at a good price. During the first half of march, I will be in Philly, NYC, Pittsburgh, SFO and LA. Thanks in advance.
Did the 30 sec test at 3500rpm and got the whining / Whistling noise for a second or two. Looks like I have found the problem. The car was bought with the 2 year CPO but I don't expect it to be replaced as I bought the car at Pacific Porsche in LA and the car is in the Philippines. I have asked them and got no reply. I need to buy the part and I will be in LA on the 13th of March. Do you know the best place to buy it?
What is "the 30 second test?" and what did you determine to be the problem? What part are you buying?
The 30 sec test is done by putting your foot on the accelarator for approx 30 secs and keepiing the revs between 3000 and 3500 rpm. Then let you foot off. If you hear a whining sound, it is most likely the power Steering Fluid reservoir
Thanks for that. Do you mean the reservoir for the Power Steering or the Transmission as in the gearbox?
Sorry, I am new to the forum and so cannot PM you. I have an exact problem as you described and want to diagnose it correctly, hopefully with your past experience.
Rgds
Rgds
sdg1871
10-05-2015 07:05 AM
