Rough Shifting (6spd)
My transmission feels rough. My car has 30k miles and it doesn't feel smooth to shift. Do you think I need to change my transmission fluid? Also what brand do you guys recommend?
I would like to try this as mine is hard to shift into first when cold.
After warm up it shifts great.
Marty K
I had the same problem with my 993 and i found a solution. A lot of people put Mobil 75w-90 Gear Lube thinking that is the factory spec. There is only one place in the USA that i'm able to find the real formulated for Porsche Mobil Delvac 75W-90 gear lube (dealer aside).
Prior to using this specific Mobil Delvac product, i tried Redline, Swepco, regular Mobil 1 75W-90. Each of them had slightly different shifting characteristics - but none of them nearly as good as Mobil Delvac 75W-90 gear lube. It is also my understanding that the dealer sells the correct stuff for about $100/quart (talk about black gold).
In any case, this is the only place i found in the US and it is $42.50/gallon. Try this and report back. It transformed my 993!
http://www.lufteknic.com/Merchant2/m...ode=lubricants
Good Luck!
Marty K
Good Luck!
I don't have a short shift kit. When its cold its even worst. I had a 02 Turbo before with much higher miles and the shifting was much smoother. My car also seems to grind a lot too when I shift fast.
andbos
09-07-2015 07:13 PM
