Stock Fuel Line / Rail HP Limit?
If cost is not essential,you should install a bigger pump and bigger injectors and fine tune your software on a dyno...otherwise raise the fuel pressure
This is what I opted for...
MK
MK
I know that Kevin (and every tuner) has spent a lot of time working this out. He is doing some huge builds now and has spent a lot of time on fuel... That time is his livelihood. Same for the other high end tuners. Once you get up to this level, it is not inexpensive, simple, or trivial. Or safe. Call him and ask him about boost controllers.. :-) (not something I did, but he has seen some peoople destroy their own engines via this route....let's assume these were very smart guys)
I would ONLY go to this level with a tuner on board. I fully listen to guys like Markski and Woodster on these subjects.
Yes, absolutely, there are better ways to increase fuel than using a higher pressure FPR. It is just an effective, easy, and cheap way. It is certainly not as good as a larger pump, larger injectors, larger lines & rails, better tuning, or changing to low impedance injectors. I just want to know who has seen injectors fail due to a 5 bar FPR, or is it a theoretical concern as skandalis so eliquently described.
Myth Busted!
OK, I got some manufacturer's data for RC Engineering and Siemens.
All RC injectors (both peak & hold and saturated) have a minimum fuel pressure requirement of 30 psi (2 bar) and maximum of 100psi (6.9 bar).
Siemens Deka 60lb injectors have a listed operating range of 250 kPa (2.5 bar) to 600 kPa (6bar).
OK, now that the myth has been laid to rest and we know that the injectors themselves can operate fine at 5bar of fuel pressure, I am compelled to get on my soap box:
If there is information out there concerning problems with fuel upgrades, why don't you guys post more info (even if it is to say "I don't have any more info than that")? You might prevent someone else from repeating the mistake.
<cue national anthem recording in background>
It reminds me of the 1960s, during the US-Soviet space race. Russia did not share their findings about a 1961 onboard oxygen fire to the US. That info may have saved the lives of the 3 Apollo 1 astronauts tragically lost in an on-ground disaster.
Let's remember we are all members of this race, the 6speed race, the get more power race, the human race. Compete, be fair, be honest, and...and uh, vote. Yes, that's it, vote. Be sure to vote. I'm out.
<fade anthem>
<fade anthem>
04-28-2022 12:38 AM
Lowtush
01-25-2022 10:48 AM
turbotuner20v
09-11-2015 12:02 PM
ModBargains
Audi Vendor Classifieds
09-01-2015 05:26 PM
pwdrhound
08-23-2015 07:36 PM
