PE 700 whp?
Old 03-09-2008 | 02:45 PM
carbonbmw's Avatar
carbonbmw is infamous around these parts
PE 700 whp?
How much WHP should a proto 700 produce? also what turbos does it use?
Old 03-09-2008 | 03:11 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Low to mid 600s.
K24/18Gs
Old 03-09-2008 | 04:41 PM
carbonbmw's Avatar
dgreen78 have you ran the 1/4 mile yet? or what do most pe700 cars run in the 1/4 mile or even a 60-130 time.
thanks guys, I might end up buying this set-up and just wanted to know
Old 03-09-2008 | 04:43 PM
dgreen78's Avatar
I have not, hopefully in the next month or two I will get out there.
LOW 11's or mid-high 10's with RWD and slicks seems to be the norm. Just all depends on driver.
Old 03-09-2008 | 05:28 PM
unvmy996's Avatar
d maffo ran 10.88 with with 650 kit . so its all driver .
Old 03-09-2008 | 05:49 PM
Dr_jitsu's Avatar
Although I have some Evo and S-car _Go stuff on my car, my tuning and fuel system (MAF, etc) is Protomotive and I make close to mid 600's on high boost, 590 on 1.1 bars.
I have GT 28 turbos but Todd has been making mid 600 all day w/ his 18/24s if you have everything else (see Woodsters car).
jamie made 715 w/ GT 30's.
Old 03-09-2008 | 05:59 PM
Turbo Fanatic's Avatar
Low 11s and very high 10s seem to be the target with a good driver. the 1/4 is all about the launch and shifting and these cars are hard to launch consistently.
Old 03-09-2008 | 06:12 PM
Divexxtreme's Avatar
When my car was a PE700, it made 580 rwhp on a Dyno-Dynamics dyno...which translates to around 675-700 crank HP. I ran a 10.65 @ 136 with drag radials and RWD, but never measured my 60-130 times.
Old 03-09-2008 | 06:57 PM
Some guys run low 11s and some high 10s... it comes down to your set up for the run. tires, weight, etc...
Turbos are K24/18gs
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 03-09-2008 | 07:40 PM
nerdhotrod's Avatar
nerdhotrod is infamous around these partsnerdhotrod is infamous around these parts
Originally Posted by dgreen78
Low to mid 600s.
K24/18Gs
Closer to mid to high 500's from what I have seen.
Old 03-09-2008 | 08:21 PM
WOODTSTER's Avatar
PE700 is a good strong package but do NOT expect 10's (same is true for GT700)
NertRod:
Mid to high 500's AWD
Mine made 628 RWHP on Proto's DynaPack (which can read slightly high)
I agree with Scott at Divexxtreme and based on several of my ACTUAL Perfomance
numbers in real world situations: 650-675 crank HP @ 1.3 bar
I ran an 11.03 at 134.5 mph on my 19" Michelin Street Tires (PS2) after driving my car
2 hours each way to the drag strip on them. I did NOTHING to prep the car, drove
thru the water box, did a sissy *** launch and some granny shifting and produced several runs in 11.03 to 11.18 all at 133.5 mph or above.
A more AGRESSIVE driver in my car on THAT SAME DAY would have easily broken into the tens. You also see my 0-186 mph is 27 seconds flat and 60-130 mph has been in low to high 6's.
MK
Old 03-09-2008 | 08:29 PM
nerdhotrod's Avatar
Originally Posted by WOODTSTER
NertRod:
MK
We have to throw it up on DB's dyno next time Im out your way . I would love to see what it makes.
http://www.dbptuning.com/services.htm
Old 03-09-2008 | 08:32 PM
WOODTSTER's Avatar
In order to do that, you would have to follow up and call me while you are in town
MK
you have my number!
Old 03-09-2008 | 08:33 PM
Here is a dyno on a full 24/18gs... granted it's one of the best I have seen....
9.66
click to view
Old 03-09-2008 | 08:34 PM
nerdhotrod's Avatar
MK
you have my number!
We'll be back soon. Hopefully tuning a few 996's next time.
