2005 Turbo S Cab
Old 03-09-2008 | 07:12 PM
xlr8's Avatar
xlr8 is infamous around these parts
2005 Turbo S Cab
I sold my 2003 X50 Turbo. It had a Evoms/GIAC flash with diverter valve's. The car ran great. Very fast. It put out 1 bar. I bought a stock 2000 mile Turbo S Cab. I took it out today for the first time. It felt very weak. Im not sure if I just got use to the GIAC flash or what. The boost was about .7 and I saw .8 bar once. I plan on having it flashed in a few weeks. I am going to do a dyno run before and after. My X50 put out 370HP to the wheels stock and 439 HP to the wheels after the flash. Any thoughts?
Old 03-09-2008 | 07:23 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
I have the same car with the Revo flash and run VP MS 109. Extreamly fast!
Old 03-09-2008 | 07:25 PM
jagsiva's Avatar
jagsiva is infamous around these parts
My TTS Coupe did 0.8-0.9 consistently when stock and now with Kevin's UMV 94 Octane flash does 1.2-1.3 (may drop a little when the weather warms up).
Old 03-09-2008 | 07:27 PM
xlr8's Avatar
What would make my boost only .7 bar ?
Old 03-09-2008 | 07:38 PM
jagsiva's Avatar
Could be loose hoses or diverter valves. Your car should be under warranty still, why not have the dealer look it over?
Old 03-09-2008 | 07:56 PM
Turbo Fanatic's Avatar
should run consistent .8 with occasional spikes of .9
Dealer should look at it and fix it for free.
Old 03-10-2008 | 03:19 PM
ttpower's Avatar
ttpower is infamous around these parts
You may have a problem. You should be getting .8 pretty consistently. Have the dealer check it out.
Old 03-10-2008 | 04:15 PM
robertp's Avatar
Yes, .8 and .9 bar.
Old 03-10-2008 | 04:34 PM
wross996TT's Avatar
Get the codes read ASAP (if you didn't do it before the car was bought).
Old 03-10-2008 | 07:58 PM
xlr8's Avatar
I took the car out again tonight. It seemed to run a little better. I saw mostly .7 and a few .8 and even a .9 after I backed off the gas. I have a thought. The gas was in the car for 4 or 5 months. I filled it up with fresh 93 octane 50 miles ago. Can old fuel effect the boost? I made a appt for tomorrow at the dealer. I do not think they will find anything. The car seem to make more boost and power at 90% throttle vs full throttle.
Any Thoughts?
Old 03-11-2008 | 02:17 AM
robertp's Avatar
Gas could be the issue. Fille her up again and make sure you run all of the old gas out and confirm it is not a gas issue before you bring her to the dealership.
Old 03-11-2008 | 05:16 AM
mmmmm's Avatar
mmmmm is infamous around these parts
In my X50 , I thought it was easier to hit .9 in the summer as oppose to now. I can only hit .8 now. Rarely will it see .9. Someone has said it was winter gas.
Old 03-11-2008 | 10:10 AM
ttpower's Avatar
Any Thoughts?
Gas can definitely be an issue. Old gas can definitely affect the performance. Running it almost down to empty and filling it up a couple of times will definitely eliminate that factor.
2lflat4
11-18-2019 05:05 PM
PelicanParts.com
996 Turbo Vendor Classifieds
08-20-2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-20-2015 02:37 PM
PelicanParts.com
08-18-2015 03:43 PM
PelicanParts.com
08-18-2015 03:42 PM
Quick Reply: 2005 Turbo S Cab
