Banging Noise While Going Over Bumps -- Solved
Old 03-12-2008 | 02:57 AM
ELMEL's Avatar
ELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud of
When I go over bumps, I hear a banging noise behind me. For the longest time, I assumed it was the suspension (sorry Alex, my bad), but I just discovered that it was actually the sunroof. My ears tell me the sound is coming from much further behind me, but I guess my ears have been playing tricks on me.
If the sunroof is closed, I hear the noise. If it's up, or back, I don't. If it's closed and I apply gentle pressure from the bottom (with my hand), the noise goes away.
So, I experimented with some adhesive foam tabs. I tried them everywhere. The following pics illustrate what worked for me. I know it doesn't make any sense when you look at it, but it works. I don't really even understand why.
If you have the same problem, give it a try. I'd love to hear other people's experiences.
Click the images to get enlargements...
Old 03-12-2008 | 03:04 AM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
Is this the slight high pitched "klanging" noise that you thought came from the suspension as you hit small bumps?
You might have just solved my $100M question ...
I'll try this tomorrow and report back
Old 03-12-2008 | 03:16 AM
ELMEL's Avatar
I should mention -- I found an easy way to test...
Get in the car and slam the door closed -- not violently, but not gently. If you hear a similar noise to the banging you hear when you go over bumps, then you've found it. Once you apply the foam, slam the door to test your repair. Worked for me.
Saint Ari, I'll settle for 10%.
Old 03-12-2008 | 03:20 AM
Saint Ari's Avatar
LOL ... I'll test that "theory" on the violent roads of ... Mission and 5th Street tomorrow... LOL
Old 03-12-2008 | 07:37 AM
porschedude996T's Avatar
porschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really nice
So what is the root of the problem? Shrinking seals?
Old 03-12-2008 | 08:19 AM
NorthVan's Avatar
another good reason for no sunroof!
Old 03-12-2008 | 04:34 PM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
I had the exact problem. My solution was to put Velcro tape, the soft fuzzy side, along the bottom where you placed the foam. It seems to work well.
Adam
Old 03-12-2008 | 04:40 PM
sharkster's Avatar
Hah!!! You just solved a very very neat problem Good on you and beers on us
Old 03-12-2008 | 04:54 PM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
C'mon, tell the truth....Buzz figured it out for you!!!!!!
Old 03-13-2008 | 12:14 AM
ELMEL's Avatar
Have you had people complain that their suspension or exhaust was making noise and you couldn't find the problem? That would suck if you wasted all that time and it turned out to be an issue with the sunroof.
Old 03-13-2008 | 02:35 AM
BLKM3's Avatar
BLKM3 is infamous around these parts
In my car around 3k, I have a very fast machine gun rattle. Its coming from the plastic bar right before the rear window. Ever since I installed the straightpipes, it rattled the whole car loose!
Old 03-13-2008 | 03:25 PM
benguss's Avatar
benguss is infamous around these parts
I told the wife I needed parts to fix "noise" problems and when it didn't I had to order more parts....so don't tell the wife this fix!!!!
Old 04-06-2024 | 09:25 AM
Ss997's Avatar
Ss997 is infamous around these parts
Loud clunk
@ELMEL
Hey my friend! I just added a roll cage, but now experiencing a loud clunk like your describing. It seems like its coming from the back, but could be the sunroof. Do you have any pics of what you did to solve the clunk? Also, i am local in bay aea.
adnanm3
10-25-2016 09:38 AM
rob4wellness
10-02-2015 08:32 AM
Sales@RSW
Lamborghini
10-01-2015 03:01 PM
ModBargains.com
996 Turbo Vendor Classifieds
10-01-2015 12:48 PM
Ronny-
09-30-2015 08:30 PM
