EVO Wastegate Rod Broken - HELP
Old 07-29-2008 | 04:31 PM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
Oak,
Now it makes sense.
I don't know what turbos FVD uses but perhaps they aren't as big as the ones on cohare's car. After a certain point the compressor gets so large in diameter that an offset rod must be utilized because of the fixed position of the wastegate actuator and the linkage rod on the wastegate. If the turbos aren't very large then I suppose stock linkage can be used.
As I mentioned eaarlier in this thread, his ultimate solution will be external wastegates which eliminates the rods altogether. I also suggested an EBC.
  #32
Old 08-02-2008 | 01:49 AM
Zippy's Avatar
My drivers side rod broke a few days ago. I'm going to see if I can get it welded back together tomorrow AM.
Mike
  #33
Old 08-02-2008 | 03:47 AM
oak's Avatar
oak
thanks al, I get the offset problem. can you use the one kevin from umw sells? of are the offsets different?
  #34
Old 08-03-2008 | 09:41 PM
WOODTSTER's Avatar
I had my welded and re-adjusted.
The alternative on mine (K24/18g's) was to have Proto make me a new one.
good luck and the driver and passenger sides are different.
As it was, the passenger side is the difficult one to get at.
MK
  #35
Old 08-03-2008 | 10:46 PM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
As far as I know...Kevin sells the wastegate "kit" which contains a stiffer spring and a set of retaining rings to put your OEM wastegate back togetehr after you break it open and remove/replace the springs...then put it back together again with the retainer rings and screws which sandwich both sides of the split wastegate back together and pinch the diaphram back in place. Uses the OEM parts, hence no problems come up with the actuator rods breaking. This is not a bolt-on process and involves some better than average or novice know-how....but the results are worth it.
  #36
Old 08-03-2008 | 11:50 PM
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
My broken Evoms wastegate actuator issue has recently turned worse, appearently this is a symptom of my other turbo blowing. My driver side turbo is now "out of thrust" not totally sure I know what that means, but it needs to be rebuilt/replaced. I am told the broken wastegate tried to compensate for the broken turbo and broke the weakened actuator. I wont get into design or build philosophy. Bottom line, there are a bunch breaking.
Im not saying that a broken actuator is a sure sign of a blown turbo, Im sure it is one of many scenarios. I'd like to hear more from others about this.
btw, I am looking for a pair of oem wastegate actuators if anyone has a set laying around. PM me please.
Originally Posted by deepblue
Same thing happened to me yesterday on the Passenger side EVOMS wastegate, the rod simply snapped in the middle. Did anyone find out any possible causes?
awesomebang
07-05-2017 09:48 PM
10-02-2015 03:23 PM
leevg
New Member Introductions
09-28-2015 06:59 PM
panas001
09-27-2015 03:51 PM
ECS Tuning - VW
09-25-2015 11:48 AM
