Getting to 600hp - questions
Hi All,
I have a 2002 Turbo 6sp non X-50 with the following mods: GIAC Flash, Remus Exhaust and Ceramic Coated Headers. 2 questions:
1) What's the easiest/cheapest way to get to the 590/600hp range?
2) What's the best way (ignoring cost) to get to this hp range while ensuring good drivability and longevity?
The GIAC flash cost in the neighborhood of $2K. Is this a throwaway or can the same program be used for higher hp applications. I know I get a credit if I upgrade to the K24 program.
Thanks in advance for the replies!
-FJ
-FJ
that's how I did it also. proven hybrid turbos and Protomotive programing.
this assumes you have diverters and probably boost hoses upgraded.
also a 5 bar FPR. consider GT2 IC's
Find used Fabspeed's for about 1k.....Gen 1/2
Yep, K-24 or better turbos and programming should have you about there. I am running Evo's new GT-610 kit which uses GT-28 turbos, headers, Fabspeed exhaust and GIAC programming (keep you eyes pealed for the kit release) and we made well over 500 whp.
Hi All,
-FJ
-FJ
Tim
The amazing part is that all that is required to get you there can fit in the palm of your hands. 1 5 bar fpr, 2 16g compressor wheels and a flashed EPROM.
Hey FJ,
Agree with Tim except I know that Stephen can take care of the EPL package for you. Give him a call 913-310-9927 thanks
I DO NOT suggest a set of k24 turbos over this set up for its super laggy. No turbo will spool as fast as EPL's set up.
S
S
Hi FJ,
I just purchased an '04 996TT Cab that had already been dialed into 600hp by Stephen at ImagineAuto. Car is a hoot to drive. If you are close to him, I'd definitely give him a call. When I first found the car, I was concerned about the mods, but the more I read, the more excited I got. Now having driven the car, I don't know why anyone would want a stock TT!
Ken
Ken
Regardless the "tune" direction you go, I'd plan to also upgrade the DVs, wastegate springs, turbo hoses and the 5bar FPR for a total package tune (Make sure to coordinate this with your tuner). That combo of parts is gonna run you about $1200-1400, depending on who you get them from. I recommend getting the SAMCO hoses from AWE.
Mike
Mike
Seek and you shall find......800 bucks, just posted
https://www.6speedonline.com/forums/...d.php?t=123617
