What is the approximate cost of an alighment and corner balance?
Hi, Corner balance and alignment are one thing... Do you have the rsr rear toe links, adjustable upper control arms? Are you looking for more camber in the front end with the gt3 lower arms with shims? Or you can do a preferred street alignment with corner balance. If you would like I will Pm you our best price!
Tim
Tim
I'm running trg front and rear droplinks ,h&r rear sway and stock everything else
please do pm me pricing on some different options
Just paid $240 for corner balance and alignment with KW V3's on the car from Johnson's Alignment. They did an awesome job.
How are you liking them so far, and what else did you change as far as other suspension bits?
Tim
Tim
Elliot
I think they're great. I just went to the track with them and I liked the adjustability of the compression and rebound. On the street I can soften them up for a nice rice. Much better than the horrible stock stuff. I don't have anything else by way of suspension on the car but I will be adding GT3 lower control arms for more neg. camber in the front. I actually ran the car without the rear sway bar to keep the oversteer in check. It worked great. I'll probably switch to the GT3 front and rear sways for some adjustability.
I got my GT2/Moton's fully setup top to bottom for 350, 650 is out of controL!
I just got it done today $394
They set my front negative camber at -1.5 as far as it would go and the rear at -2.4.
Does this sound about right?
