How much boost to set for K24/18G with Greddy Profec B Spec 2 & Turbo Timer ?
Old 03-24-2008 | 03:57 PM
RWDRIFTC2's Avatar
RWDRIFTC2 is infamous around these parts
Auto Talent is about to install the Greddy Profec B Spec 2 into my 996TT. My question was how high should I set the peak boost at? I only plan on running 91 octane fuel. Also do I need to run a turbo timer in the car?
Current Modifications
Softronic Programming
K24 18G Turbo Upgrade
Fabspeed K24 Headers, Exhaust, and Cats
EVOMS Intake System
OEM GT2 Intercoolers
5 Bar Fuel Pressure Regulator
Spec Stage 3+ Clutch and Flywheel
TIA
Old 03-24-2008 | 03:58 PM
nerdhotrod's Avatar
nerdhotrod is infamous around these partsnerdhotrod is infamous around these parts
What software do you have? Are you doing this on stock ecu?
Old 03-24-2008 | 04:12 PM
RWDRIFTC2's Avatar
Sorry Custom Softronic K24/18G Programming
Old 03-24-2008 | 05:16 PM
unvmy996's Avatar
im running 93 oct and have mine set at 1.1 bar. and no u dont need a turbo timre as a matter of fact the 996tt doesnt like turbo timers u cant lock while it runs.
Old 03-24-2008 | 05:17 PM
vividracing's Avatar
Turbo timer is for girls....
turn the **** and go to about 50% to start, set your gain at 10%, set your warning at 1.3, have it pull back at 20%. Watch your peak boost which is the last setting. Look for about 1.1bar at 3rd gear pull. just call me if you need help.
tony, we got the tuning covered, dont worry...
Old 03-24-2008 | 06:46 PM
nerdhotrod's Avatar
Im sure you do...I was more concerned he was using a stock ecu.
become a vendor, i see you have on Rennlist...
Old 03-24-2008 | 06:54 PM
Turbo Fanatic's Avatar
Where is so cal are you? I'd love to exchange test drives.
TIA
Old 03-24-2008 | 09:05 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Also, I would watch your AFRs!
Robert
Old 03-24-2008 | 09:12 PM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
I'm certainly not trying to disrespect, but if they don't know what boost to set your controller at, I'd have questions.
Old 03-24-2008 | 09:42 PM
tom kerr's Avatar
I run mine at 1.1 bar at the track with 100 octane. but I am trying to be cautious. my AFR's at WOT are about 11-12.
I think with the low octane you have I sure would not run much above 1.1. and the car has sooo much power at that level.
Old 03-24-2008 | 10:46 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
I agree with Tom and others. I set mine for about 1.18 peak on 93 octane and have plenty of power...I don't feel the need to turn up the boost any higher. I will run 1.24-1.28 on 104 race fuel, but honestly, I am not sure I can feel the difference...
Old 03-24-2008 | 11:00 PM
RWDRIFTC2's Avatar
I am just trying to get a general consensus on how much peak boost the car should be running.
1 bar
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 03-24-2008 | 11:05 PM
Onetime's Avatar
No problem man, I just want your car to be done right. They're too expensive to make a mistake with.
Quick Reply: How much boost to set for K24/18G with Greddy Profec B Spec 2 & Turbo Timer ?
