whining sound coming from my engine compartment
hi there,
my car started to make a whining sound coming from the engine compartment when i start the car in the morning. it will depress if i depress the clutch now it is coming more often even if the car is worm but only at low RPMs and still goes away if i depress the clutch.
Any ideas on what it might be?
Thanks Guys fir your replays.
It seems like it is my Clutch Accumulator as i do have a funny clutch peddle feeling and it is very stiff when the engine is off. Now, do i only have to change the accumulator and be done with it or is it more involving?
Thanks.
Thanks.
This is your problem. I changed the reservoir myself. This is what I sent to my buddy Mike at Carlsen Porsche and I quote. The PN below is what you need.
I have had this annoying high pitched noise coming from the right side of the engine bay. It is a high pitched whistle noise (Valve Flutter) that only appears when coasting down at between 1-2K RPM, as soon as I depress the clutch it goes away. I have replaced the clutch slave cylinder and expansion ball.
TSB 4897 01/05 Replacement PN 996 314 920 34
turbotuner20v
09-11-2015 12:02 PM
Fabspeed Motorsport
Audi
08-21-2015 11:30 AM
