Question: why is my steering wheel shaking?
Hey fellas,
I have JIC Cross coilovers, rear control arm, anti-roll bars and new stock brakes. The car has been aligned recently. When I brake hard, my steering wheel shakes like crazy. The car doesn't pull in any direction under hard acceleration or braking. Everytime I come to a quick stop, the steering wheel shakes and vibrates. its driving me nuts. This can't be normal.
Jack her up and give the front wheel/hub a little shake back and forth, I once found my steering ball joint had worked a few threads loose and caused the exact same issue. I know have all nuts/bolts painted.
If your car shakes slighly under really hard braking you might be experiencing the ABS controller feedback as it acts like a stepper motor very quickly applying and unapplying your brakes quickly to avoid lockup.
Does the car pull in either direction or does the car step out in the back?
Rotors were turned I believe and new pads. My breaks are squeaking a bit as well. I never noticed it until the brakes were replaced. you are probably right. I'll have my guy check it out.
thanks everyone. I was afraid of that. now more time in shop...more money. Thank God one of my cars is stock
strictly under braking, otherwise very smooth. Am I the only one who has constant minor failures after making the mods? I wish I would have just left her alone....well maybe a chip and exhaust And well, ****, if you're going to chip and exhaust, might as well do........... yup a disease without a cure. Thanks fellas
04-28-2022 12:38 AM
cnebrask
09-17-2015 09:19 AM
