Great News! Custom Upsolute with StageII Turbos!!!
Originally posted by ebaker2
What is the A/F ratio under light throttle cruise or slow acceleration? Do you need a lift to remove and replace the turbos?
I didnt use a lift...just jackstands and a very comfortable creeper! LOL! If you do it...be sure to label all your bolts, etc....you dont want to end up with more bolts or vice versa! LOL!
Originally posted by emorgan
I have a totally stock 03 GT 2. What difference would I notice with the upsolute ecu?
There are a number of Upsolute GT2 guys out there....PM John Revis...I know he has it.
Originally posted by StephenTi
But it looks like for me, all I need is the turbos, pay the upgrade charge, and I'll be ready to rock and roll!
You HAVE to keep us posted as to the dyno numbers once they are available. Since you've already got your regular Upsolute dyno files already, it'll be really interesting to see them overlayed!
This set up rocks! If you're happy with your upsolute now, you'll absolutely love this one. Boost is crisp and very responsive. Im thinking about getting either the SP or Akkurat HKS BOVs..wondering how much more responsive the turbos will be?
I'll try to get it on the dyno soon and will report back.
I have a totally stock 03 GT 2. What difference would I notice with the upsolute ecu? I do not track the car and most of my driving is around the city. Two guys moved in down the street from me and both drive Vipers. I know the day is coming when we will meet at the traffic signal. What can I expect if I decide to do a quick race to 80 mph?
First of all, thanks for the write up. Its a good one indeed. I was wondering when Upsolute would customize their programs to step up from the K16's.
Do you have any Check Engine Light issue? I Put the Upsolute in my red turbo, and it runs great. I do get a check engine light, and perhaps Renee can tell me how to clear / resolve this. The car does pull hard. I would like to know if Upsolute can customize a setup running similar to a stage 4GT program.
My black stage 4 GIAC program ran neck and neck to my buddy's 600HP VIPER GTS. The Stage 4GT pulled about 6 cars in front. during 3rd to 4th. Perhaps Upsolute can cuztomize a bigger set of turbos to run close to GIAC Stage 4GT.
Stage4GT GT2 vs. 600HP Viper GTS - please right click and save as
I talked to rene about this setup as it would require probably 15% more fueling than my stageII turbos and he said they could do it no problem. It might require you to run larger injectors, however, they have the abilities to do it. If you decide to go this route...definitely speak to both kevin and rene. You could use my file as a baseline and fine tune from there.
As far as CE lights...none. No PSM/ABS issues...just rock solid performance!
You should pick up the Harrison R&D datalogger...it hooks up to your OBDII port and can log data at a rate of .001 secs. Plus, you can diagnose you CEL and clear it.
http://www.ghg.net/dharrison/
I took the car out last night for a spin as it was nice and cool here in NJ (65 degrees)....nailed 2nd gear...boost jumped to 1.2 bar and held all the way to redline! Now, that was fun!!!!
Originally posted by BCS996TT
From speaking to Kevin...if you go with a StageIII turbo and custom upsolute running 1.2/1.3 bar, you will be in StageIVGT territory...possibly more. Those turbos can run 1.3 bar all day long and are significantly larger than what I have.
Well someone fwd me Renee and Kevin's contact info.
Shank
Shank
Shank
Kevin: kmatwichuk@att.net
Tell rene that you're thinking about going with the stageIII turbo...but first speak to kevin and get the parameters of the turbo so that rene knows what baseline to start you off with.
Keep me posted as i'll probably want to move up to this setup later on!
Originally posted by gneypiks
bcs;
re the data logger,is there a specific model that is compatible?are there instructions that comes with it (eg.how to diagnose,clear cel,etc).
bcs;
If you're 2002 or older....OBDII... 2003 and up I believe use CanScan. Confirm with Dan Harrison (owner/developer)
It's pretty straight forward...install the software, hook up the cables to your laptop, to the connector and to your obdII port (look down by your left knee under the steering column and you'll see the port). when you run the application....connect to the ecu and it will run through the diagnostics window. You can then log data as you wish...set the sampling rate, etc.
If you have any questions...Dan will guide you through the steps. Very nice guy and very fast to resolve any issues.
Best part of it all...updates to the software are free...so it only gets better and better!
bcs,
I have a tiptronic currently running the regular Upsolute which is fantastic! Just today I blew away an SL55 starting out at 90MPH. Do I need to do anything to the tiptronic to handle the stage II Upsolute? My obvious concern is that the tip may not be strong enough to handle that amount of power.
