Help! Gauge Ring Install Question...
Old 04-13-2008 | 07:45 PM
BlueRanger's Avatar
BlueRanger is infamous around these parts
I just installed some gauge rings and cant seem to finish the last (smallest/end) guage rings. I actually ended up scratching the surrounding trim .
The instructions say to start at the bottom and work your way up pushing the alum. gauge ring between the surrounding trim and the oem black gauge ring.
It just doesnt fit and scratched the surrounding trim.
Please if anyone has some tips they can give me I would really appreciate it!
Old 04-13-2008 | 08:02 PM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
Well, you might not like the answer, but I pulled the cluster and did them out of the car,this way it gave me lots of room to NOT scratch the surround, mine is carbon and that would have been a shame. No not use glue, clear silicon or good two sided tape.
Old 04-13-2008 | 08:08 PM
BlueRanger's Avatar
Can you tell me how you removed the cluster?
I used two sided tape.
Thanks!
Old 04-13-2008 | 08:24 PM
kilrgt's Avatar
Do a search, I did do a DIY for this a while ago for someone else, its not difficult, but make sure you put a towel on the dash behind the cluster....if you have leather it will dent easy..
Old 04-14-2008 | 02:46 PM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
I had to bend mine slightly to fit perfectly. I finally got it to work great. I attached my rings with silicone. It is quite easy to remove if you take the rings off later. I used tape to hold it in place while the silicone dried overnight.
Adam
Old 04-14-2008 | 10:49 PM
porschenut911's Avatar
porschenut911 is infamous around these parts
Need to bend it and sand the edges first. Use clear silicone and then blue tape while they dry. It took mine about a full day to dry.
Old 04-15-2008 | 06:24 AM
Ray C.'s Avatar
Ray C. is infamous around these parts
I used 2-sided tape on mine 2 years ago; still looks great.
Old 04-15-2008 | 06:45 AM
wross996TT's Avatar
I am having trouble understanding the issue. I used UHU Tac, the rings fit right on and have never come off...that was 4 years ago. Would never remove the cluster for this mod.
Old 04-15-2008 | 09:31 AM
Freier's Avatar
Freier is infamous around these parts
Hi Wross, do you remember where you bought your rings from?
thx!
Old 04-15-2008 | 01:07 PM
wross996TT's Avatar
Hey, I'm out of town all week, but will check when I get back next Monday
Old 04-15-2008 | 07:55 PM
BlueRanger's Avatar
Thanks for the tips....
I will try to bend and sand the edges.
04-28-2022 12:38 AM
10-06-2015 05:20 AM
turbotuner20v
09-11-2015 12:02 PM
Quick Reply: Help! Gauge Ring Install Question...
