Add 30 hp on a K24 kit?
I'm thinking about the waistgate kit from evoms that is still internal but holds more boost.
I know you said you didn't want to do hybrids, but honestly the wastegate install would probably be almost as much work as the new turbo install (the hardest part is getting stuff out of the way to get at the turbos). You can get your K24s turned into K24/18gs and have upgraded wastegate actuators installed on them while they're out for cheap (should be in the $1200 neighborhood).
You'll have to forgive me for being stubborn but coming from a corvette which was highly modified I am very skiddish about doing "too much" to the car and it starting to break down, I know Al Nortons car breaks the rods on the waistgates all the time, I dont want to risk any problems because of going to far. I just need a little bit more power, and would rather start off with the little things that free up air flow and boost.
I may crack and get the hybrids, but I get satisfaction on doing the most with the least.
http://www.evoms.com/marketplace/Vie...00E34BCACB0%7D
Tim
I should have been a artist !!!
this will also help
https://www.6speedonline.com/forums/...gate+adjusting
On second thought after viewing that thread, I do have the right size. But it seems to big for the little metal end that is connected to the black tubing on the waistgate.
I dont want to break anything. and mine is pointing up instead of down, can I rotate it?
Ok, in light of 9elevens recent snappage of wastegate rod, I'm not screwing with it. I know Al had the problem MANY MANY times because I watched Neil always replacing it. Al told me Cleve had the same problem in his GT2 always carrying rods to the track. Exactly what I want to avoid. Especially since I'm already boosting 1.1 spiking at 1.2. I do not want to be at the track changing rods, I barely have enough time for pads and rotors when needed.
Derboost thanks for all the help on that though.
So on to plan B:
Air Box- Trying one from Vivid, will post dyno results.
DV's - Have some, just havent put em in. May do that now.
So the verdict will be:
1) If I dyno 520 or higher (dynojet) with the Vivid Box and DV's I'm leaving her alone.
2) If I'm much less than 520 then I get hybrids
So on to plan B:
Heavy, just replace the springs in your stock wastegates, then you won't have the problem of snapping the rod. UMW sells a kit where you just replace the springs and they will perform like the EVO wastegate. BTW, EVO just called and told me that they are aware of the problem and have designed a new rod. It seems that the old rod suffered from heat and was compromised. They are sending me the updated set tomorrow, no charge. We'll see.
