What happens if the wastegate pressure is set too high?
Old 07-12-2004 | 10:13 AM
BlackBear's Avatar
BlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud of
Is it running lean? Does it make boost too late?
Old 07-12-2004 | 10:26 AM
StephenTi's Avatar
StephenTi is infamous around these parts
Actually, the stronger your wastegate spring, the later it opens... and if it's too strong, it may not open at all.
When the wastegate is closed, all the exhaust flow (energy) is directed through the turbo. This aids is spoolup as well as holding a higher boost. However, if the spring is too strong, the solinoid that controls the vacuum signal to the wastegate may not be able to effectively control the wastegate, which results in your boost not being properly regulated. This can result in overboosting, boost fluctations, etc.
To run a stronger wastegate, you have to ensure that the solinoid is capable of controling the wastegate via its pulses/cycles. You also have to make sure that the ecu has the parameters in place to control the solinoid as well as potential higher boost conditions, and maybe even fail-safe over-boost shutdowns. Additionally, you've got to make sure that the spring isn't in fact too strong for your application.
Old 07-12-2004 | 11:28 AM
Orli930's Avatar
Orli930 is infamous around these parts
KABOOM
04-28-2022 12:38 AM
Armytrix_F1_Exhaust
07-07-2019 11:31 PM
turbotuner20v
09-11-2015 12:02 PM
oddjob142
08-19-2015 12:27 PM
Quick Reply: What happens if the wastegate pressure is set too high?
