Need a clutch that can handle 700+hp
Thanks man, you should've asked them to start it up.
LOL, thanks Alex. Take your time with the clutch problem, I am sure you'll be able to figure it out. Man, I can't wait to get the car back!
BLKM3, I am on it and have been conversing with my techs and cluchmasters to get you another clutch tomorrow. We cant keep the clutches on the shelf and have never had a problem. It could be a bunch of things but I will make sure you have something I have tested here before they install it tomorrow!
Mike@EVOMS
Mike@EVOMS
Sorry... not you... I saw LiNks' car out at RPMNorth in NY this morning.
Good luck with your setup, though! I was dropping my car off to get a clutchmaster kit installed though, so now you and Alex have got me worrying.
Seal Grey Matte, I actually took a look at your clutch to compare it to mine and it is a night and day difference. I went with a standard Stage III clutch set up for a 996tt off of the Clutchmasters website, Steel backed Segmented Carbon/Kevlar the only thing I changed was I opted for a unsprung hub..... I saw your clutch though and it definitely looked interesting, I think it should work good. Curious to drive my car and your car to see the difference.
Eddie was elbows deep in it when I showed up this morning.
Now I'm jealous. I didn't have a chance to look at the clutchmaster parts this morning because I was running so late (Tim wasn't there and the guy at the front desk didn't know where it was).
From what I was told by Louis at Clutchmasters it is kevlar on the pressure plate side and organic on the flywheel side with a sprung hub. Louis seemed to think that the sprung hub (ala stock) would take some of the chatter out of the engagement.
Does that sound like what you looked at?
That sounds pretty much identical to what I looked at, your kevlar side was a little different then my kevlar side (pattern wise) for whatever reason, and my clutch will probably be a little harsher then yours just by viewing them both, but I kind of want the toughness to go along with the power and future power, and dont want think about seeing my tranny out again for a long while ; )
Smart move. I am DONE at my power level. I have no interest in digging into the fuel system or internals and it's more than I need on the street already. If I had any inclination of going with more juice, I definitely would have made the same choice you did.
[quote=Seal Grey Matte;1810335]Smart move. I am DONE at my power level. I have no interest in digging into the fuel system or internals and it's more than I need on the street already. quote]
Yea, I have heard that one before
Mike@EVOMS
Mike@EVOMS
Thank you for your help! I hope it does the trick!
Me too!! thats why im not kidding myself anymore! I know im going to go bigger I just hope the K24's with the complimenting mods hold me over for a little bit. I would love to see how your K16/16G hybrids compare to the OEM K24's, curious what the comparison is through the power band.
Well, I'll probably be picking up on Sat. If you're in the neighborhood we should run them. But not on 495... I almost got arrested about 3 times on the way out there. In fact, a motorcycle that thought he was racing me got snagged.
I have a GIAC, EVO intake, Fabspeed Gen3, EVO DV's and am also considering a clutch improvement. The advice I've received thus far is the Sachs stage 2 to give "same as stock" driveability with the increased HP handling. Anyone else have this clutch with stock flywheel and how/what is your experience?
