Need to Replace Clutch Slave Cylinder
Old 05-01-2008, 06:06 AM
turboporsche's Avatar
turboporsche is infamous around these parts
I need to replace the clutch slave cylinder on a 2004 turbo X50. Any idea how difficult is to perform the installation? My dealer in South Florida quote me at $1900 including parts. Is this a fair price? Thanks
Old 05-01-2008, 08:24 AM
SpeedYellow's Avatar
SpeedYellow has a spectacular aura aboutSpeedYellow has a spectacular aura aboutSpeedYellow has a spectacular aura about
no that's not a fair price. the 996TT you can drop the motor W/O dropping the transmission. the PART is only $500.00 so you're not looking @ more than 5 hrs labor. just had mine done. get it done NOW, though.... you start GREASING up the clutch disk and indeed it will be a $4,000.00 job when you buy the new clutch and pressure plate to go with the slave cylinder. in my case I had the LWFW and the GT3RS clutch and pressure plate already done and in the midst of other servicing a few months later they noticed the slave-boot was "weeping" so we did the R&R immediately.
Old 05-01-2008, 09:49 AM
Thanks for the info. I wonder if anybody knows a good and fair repair facility in South Florida?
Old 05-01-2008, 10:30 AM
RiA's Avatar
RiA
RiA is offline
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
Or you could go with the GT2 conversion. Do a search and you'll see that there is more feel to the engagement - it's not for everyone.
If this is something you would consider, see if you can drive a GT2 and the clutch feel will be very similar.
Old 05-01-2008, 10:45 AM
SlimJim's Avatar
SlimJim is infamous around these parts
I have to get the same part repaired, my friend at the dealership told me the last person he charged was around the same price as you stated...what did other people pay for this?
Old 05-01-2008, 11:15 AM
fastoc996twint's Avatar
fastoc996twint is infamous around these parts
What Are The Simptoms Of A Failed Or Failing Slave Cylinder?
Old 05-01-2008, 12:04 PM
hrs1's Avatar
hrs1 is infamous around these parts
try vinney at gulf performance its just east of 95 on copans 954.783.7345
Old 05-01-2008, 02:49 PM
Symptoms in my case were fluid spill over from the reservoir. I also started to have occasional problems shifting/engaging third gear.
Old 05-27-2008, 07:55 PM
dherrick's Avatar
dherrick is infamous around these parts
Sout Florida shop
don't know if got your problem solved but if you don't mind d a drive to W. Palm Beach, check out Orbit Racing. Talk to either Mike Hazel or Rodger Hawley.
Old 05-27-2008, 08:37 PM
spoonito's Avatar
spoonito is infamous around these parts
Is this the same thing? Just trying to help everyone out...
https://www.6speedonline.com/forums/...d.php?t=131495
Old 05-27-2008, 08:38 PM
spoonito's Avatar
Old 05-28-2008, 12:06 AM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
If your interested, I just did the GT2 slave conversion and have my low mileage slave/accumulator FS. I have about 1K miles on both. PM me
Old 05-28-2008, 12:26 AM
N1_kT's Avatar
N1_kT is infamous around these parts
damn i think thats what happened to my car. now i cant even shift. clutch is completly out
Old 05-28-2008, 05:47 AM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
All I know is I replaced mine with a NEW one from Porsche when I did my clutch and lwfw, and I'll be damned if it didn't crap out after only a couple hundred miles. Best guess is it was bad out of the box and took a little while to show symptoms. NOT a job I am looking forward to doing again. Royal PITA! One arm around one side of the tranny, one arm up the other side....At least it is under warranty..
Old 05-28-2008, 04:22 PM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
Yep, that is either a failing clutch slave or accumulator (or both). Best off replacing both. You can get to the accumulator without dropping the tranny, although it is not a simple task. The slave itself is a PITA to replace. It is on top of the tranny and difficult to reach. I'm not surprised to hear $1900.
Quick Reply: Need to Replace Clutch Slave Cylinder
